That's it.
Watch a few YT videos on a guy setting up relief, and one on intonation.
The way I do it is to tune each pair of strings perfectly to each other by harmonics, then use one as the reference for the other. It's quicker and more accurate than any other method once you get the hang of it.
Tune the E and B, G and D, and A and E to a perfect interval using the 5th and 7th fret harmonics.
Then compare the 19th-fret harmonic on the lower string to the 14th fret note on the upper string to intonate the upper string, and the 12th-fret harmonic on the upper string to the 17th-fret note on the lower string to intonate the lower string. You can leave both notes ringing at the same time so you can hear the 'beating' between the frequencies, and when you get familiar with it you can tell roughly how far out it is.
Move the saddle backwards (away from the neck) if the fretted note is sharp, and forwards (towards the neck) if it's flat - if you have trouble remembering that, it's the direction which initially makes the problem worse. You may need to detune the string a bit if you're moving the saddle backwards.
The reason this works even though equal temperament isn't quite the same as tuning perfectly to harmonics is because you're just using one string as the reference for the other, and the errors in both directions cancel out.
I then always check by playing open chords above the 12th fret, and see if any of the fretted notes sound out compared to the open strings, which will catch any mistakes.
As others have already said, all you really need is an accurate tuner and the right screwdriver/Allen key.
True for intonation, but it's worth learning how to do the truss rod. If your relief is wrong, it will affect how much pressure you have to put on the fretted note, which will increase the tension of the string, and change the pitch. I'd get the relief how I like it first before doing intonation.
- clean and graphite the nut
- put fresh strings on - make sure they’re not overwound round the pegs.
- roughly tune up and ensure the action is spot on
- correct the intonation for each string
- tune the G string to a tuner, your ear, or the record or pitch you’re wanting to play to
- tune all other strings to G by fretting them (ie 3rd fret on top E string, 8th fret on B string, etc)
You’ll be amazed at how your guitar sounds.
https://www.gear4music.com/Guitar-and-Bass/Ibanez-MTZ11-Multi-Tool-Red/20J9?gclid=EAIaIQobChMI5dHs6cSM8AIV0uR3Ch10vQgnEAAYASAAEgKvBPD_BwE
Try and get decent quality tools that fit well or you'll end up chewing things up.
Same goes for the nut height - a badly-cut nut will have the same effect in the lower frets.
The end result of this is that you'll be able to intonate one section of the neck perfectly, but then it'll get progressively worse as you move further away from that area.
For my money, the best approach is to check that the truss rod is set correctly, then check that the nut's cut properly, then set the saddle heights, then set the intonation, then tweak the saddle height to taste - because all of these things affect the length of the string when open or fretted, and thus affect the intonation.
