Otherwise you can/could buy rack-mount shelves and screw through into the chassis mountings usually I think
I've seen plenty of half width rack cases but never a 1u size. Someone like Castle Cases, 5 Star or Flightcase Warehouse would knock you one up.
You could also get a small Peli-style case to pack it in. Trifibre have their Challenger range which are very affordable and come with pick-and-pluck foam so you can make your gear fit relatively snugly. One of the smaller ones should do, you'd just have to check the internal dimensions on the website. I've got a couple of the bigger Challenger cases and they're rock solid after a good few years of being battered around on tour.
Alternatively, if you could stomach a full width case, there's rack ears for the Sennheiser that have a half width blank plate to mount a single unit in a full 1u space. You can get them with a passthrough for the antenna so it sits proud on the front of the case instead of buried in the back and will improve the transmission performance.
