Withdrawn
IsambardKentuckyIsambardKentucky Frets: 157
edited March 14 in Amps £
Very lush sounding Black panel AA1164 (Princeton Reverb) based amp.
It's a hand-wired amp using top quality filter caps and electrolytics, carbon comp resistors, Orange Drop tone caps, solid core push back wire, and custom US Heyboer transformers.  Rick also added grid and screen resistors (as seen in the Black Face AB763 circuitry). This gives the transformer more protection in case a tube fails catastrophically.
Controls: Volume (w/push pull bright switch), Treble, Middle, Bass. Reverb, Speed, Intensity, Dwell. External Bias Points have been added so it’s a doddle to bias the amp at home when you swap/change the power tubes.
Effects: Large Pan, Tube Driven Spring Reverb, Tube Bias Vibrato (The reverb circuit upgraded - the Vintage 15 uses a large 17" spring reverb pan that's the same size as the one used in the Twin Reverb!).
Speaker: WGS G12 C/S
Power Tubes: (2) 6V6 Matched pair
Preamp Tubes: (3) 12AX7, (1) 12AT7 (all upgraded to TAD premium selected preamp tubes)
 Rectifier: 5AR4 Rectifier Tube. Can be swapped for a 5Y3 to change sound and feel and drop the amp down closer to 12 watts.
Ordered with UK Voltage
VSA Custom Padded Cover and 2 button footswitch.
Combo Dimensions: 17" H x 19 7/8" W x 9 1/2" D  (32 lb)
Grill badge attached by two Philips head screws – so easy to have in position, or remove as wished.
Excellent condition – smoke/pet free home.
Price: £1400 (Straight sale no trades).
 Collection only.
Drop me a pm if you have any questions/ want further info. Cheers!
