The question just popped into my head as a result of a couple of YouTube vids I've come across recently which had people using this...
I started classical guitar in the 70s and was taught music theory at the same time to underpin it. When did people start to use the term "flattened third" for the third note in the minor scale instead of "minor third"? Ie., the 3 semitone interval in a minor key context. I realise they mean "the third of a major scale, but flattened", but in a minor key context, that grates with me. I know the third note of a minor scale is 3 semitones away from the root. It doesn't need saying.
Can someone currently teaching theory please explain? Is it a general change in terminology and everyone uses it now? Or is it a convention for certain groups of people?
I quite dislike it too because it confuses the hell out of some students when the third is not, in fact, a flat, as in A minor or D minor. I've started to say "lowered third" if I'm using that way of looking at things.
That convention relates everything to the major scale. So Mixolydian has flat 7; Aeolian has flat 3, 6, and 7. I do find thinking of it in those terms has some uses for seeing the differences between modes, and looking at the modes in sequence from light to dark.
But for anything else, anything where it is necessary to say what the notes are, starting with the standard major scale and saying "flat 3rd" is very much more understandable and sensible.
I am assuming here as a starting point that everybody knows the major and minor scales. You learn major. You learn minor. Then you learn all the other stuff and relate it back to what you know, and the thing you know better than anything else is the major scale, so that's the one to describe the new one in terms of.
If you describe new things starting from the minor scale, you are committing the sin of requiring that the student does two things at once: (a) mentally adjust from the major to the (always less familiar) minor scale, and at the same time mentally add or subtract the modifications. This is much more difficult.
Worse, once you stop describing everything (except straight minor, which anyone at this level already knows) in terms of difference from the standard major scale and start sometimes describing the differences from one scale (major) and sometimes describing the differences from some other scale (minor), chaos sets in. From the learner's point of view, does the instruction to flatten the 3rd mean play one semitone below the major third? Or one semitone below the minor 3rd?
Finally, we have the asinine dual meanings to the term "minor 3rd". Does it mean "play the third note of the scale one semitone flat compared to major"? Or does it mean "the interval between E and G, or A and C"? No wonder educators are trying to make the terms music theory uses more sensible and rational.
What a dog's breakfast. Just stick to major as the starting point and take it from there.
</rant>
Here's what I learned as a kid...
Major scale intervals: T T S T T T S
Minor scale intervals: T S T T S T T
What's so hard about that?
But back to my OP question. Why did it change? And for whom? Or is it something invented by people who could play and understood music well, but didn't have a classical European training, so lacked a common language for communication and therefore built their own?
Flatten the third is an instruction to play a semitone below the major third.
The hard part is when you describe two different things with the same term. ("Minor 3rd.") The hard part is when you describe new things starting from various different places instead of always starting from a common point. Both of these are needless and pointless complexities which should have been eliminated from music teaching decades ago. The aim should be to help people understand music, not to obfuscate it.
Except that, thinking back to the dim and distant past of my Grade 5 Theory, there's other forms of the minor scale - there's the natural minor, the harmonic minor and the melodic minor. The only thing they have in common is the minor third. I think one of them was different on the way down from the way up, too.
TBH, I found learning scales tedious and always fell down when it came to the exams. I only really cared about playing the tunes. There were some dots on a piece of paper in front of me; I played them and a tune came out. Not much has changed...
but C7 is (C E G Bb) ?
apart from the fact that it is nice, why in theory terms does the Dom7 have the Bb ?
Other intervals are either major (eg major 6th, Ab to F) or minor (eg minor 7th F# - E).
I agree that using the terms flatt(en)ed or sharp(en)ed in place of the correct terms can cause confusion. However the abbreviations are widely accepted in naming chords. For example B7b5 (notes B D# F A) should strictly be called B7dim5 but in chord naming ‘dim’ is reserved for chords based on diminished triads, eg Bdim7 (notes B D F Ab).
I'm pointing out (and you apparently agree) that it's not hard to learn two sets of scale intervals. So now we appear to have the same view on that issue, what's so difficult about using that knowledge to describe a 3 semitone interval as a minor 3rd? I don't understand what you mean by "modifications" that someone needs to add or subtract.
Just answering that point seeing as you ask @sev112 and because the history is interesting and useful. And I'm going to speak from the perspective of a classical musician, just so you get the history of it. Like if you were asking a question about quantum mechanics, I'm just being Newtonian for a minute And I'm putting it all in context of a major diatonic key.
So, "Dominant" has a specific meaning in classical music; it's the name given to the 5th note (or "degree") of the scale, and similarly it's given as the name of the 5th chord too - "Chord V". Like Tonic is the name of Chord I, Dominant is the name of Chord V.
But (in a major key), unlike a 7 chord on the Tonic, which as you rightly say is a maj7, the 7th on the V Chord is a minor 7th. We call it a Dominant 7th, but the word Dominant doesn't (originally) refer as much to the 7th interval, as to the chord position. So it doesn't (originally) mean any old lowered 7th, it refers specifically to the 7th on the V chord, which happens to be a minor 7th (but see three paragraphs down).
To restate, the origin of the phrase "Dominant 7th" isn't rooted in the 7th per se, it's rooted in the fact that Chord V is the Dominant chord.
Of course, because chord V is the only major diatonic chord to deploy a minor 7th, the term Dominant 7th has become synonymous with the minor 7th interval. So people use it interchangeably with minor 7th, to the annoyance of pedants.
Now it gets interesting. Because it's often useful to deploy a minor 7th on other major chords besides the V (eg if you want to treat another non-V chord as though it were a V chord - called a secondary dominant - or if you simply want the sound of a minor 7th on any other major chord, like in the blues, where the I, the IV and the V all have a minor 7th), the word "Dominant 7th" has cemented itself in our lingo to apply to those chords too. So now it basically means a chord in any position that happens to have a major 3rd and a minor 7th.
So, your question: why does the Dom 7 in C major have the Bb, well, a pedant would say:
"It doesn't. The Dominant in C major is the G chord. If it's played as a G7, then it has a minor 7th, the F, and it's called the Dominant 7th chord (with its dominant 7 interval, G -> F). However if you do want a minor 7th on the C chord, which is a Bb, then you have to call it a minor 7th. Unless the C7 is temporarily acting as a V chord, and resolving to an F chord, which is called a "Secondary Dominant" and does indeed have a dom7. But if it's just a minor 7th on the Tonic chord, then it's a minor 7th not a dom7."
I hope that has clarified things. I'm sure it's made it worse though, sorry lol. It's hard to write this stuff.
I’d say once Jazz education became monetised and mainstream by places like Berklee in the 70s, as with most things American, this terminology permeated elsewhere over time. And that’s where we find ourselves now... with a mixture of interchangeable terminology due to cultural/musical differences.
I'm interested to know why it grinds your gears though. Minor 3rd and b3 describe the same thing to me, located the same places on the fretboard or thought of in the same way regarding distance. Is it that you feel everyone should follow the 'classical' approach? Or that you feel your intelligence is being insulted by having b3 used in the context of minor keys?
If we were discussing a song in the key of Cm, would you object to a Cm chord (or any of the minor chords) being called as such, or would you prefer it called C with the assumption that we'd understand you're thinking Cm?
If there's no need to translate something then I'd prefer not to. Understanding that a minor 3rd is the same as a b3 isn't hard to do. Most of the musicians I've played with over the years haven't been classically-trained so we've not always used the same language to discuss music, and had to find common ground with each other. Most of them have had no formal training at all, TBH! :-) But, it's hard for anyone to overcome thinking in their first language even when they've learned another one, so I naturally speak "classical European" when I use words for music and generally think about music in that way. It resonates better with me.
I'm sure if I'd gone to Berklee to study jazz guitar rather than attend RCM and study classical guitar, I'd have a different view and naturally use the terminology that they teach their students.
Is it better or worse? No. Just different. Every system will have its strengths and weaknesses and be more suitable for one task rather than another. And every person using a particular system will know more or less about it than someone else.
I'm much happier using Berklee-style names for chords and following a chord chart, than I would be playing rhythm guitar from a score. I don't feel that the classical approach is something everyone should follow - unless it's the best system for the music they're playing. It might help some people to known more about it if they need to communicate with musicians that only know that system, but that's about it.
Your second question... I think of a chord with the notes C, Eb and G as being Cm - because it has the 1, 3 and 5 notes of the Cm scale. On a chord chart for a guitarist, I wouldn't expect it to be called anything else. That would apply to a tune in a major key or a minor key.
I wouldn't be able to sightread a Nashville-style chord chart. If the key is Cm, do they write the Cm chord as 1 or 1m?
Which reminds me that “unified theories” in physics which don’t cover everything either.
