It means that the 'off' volume control or the balance control isn't loading the 'on' pickup, so it sounds clearer.
Passive mixing is actually always a compromise, but it's just the way it's always been done. It just doesn't work well because the added series resistance as you turn down one volume control quickly cuts off that pickup and makes the range of useful tone variation very small. Active mixing solves that problem.
I dislike all 2-volume systems, in fact. I just about tolerate them on Rickenbackers because it's necessary for the stereo outputs, which I do very occasionally use - but I actually never use the volume controls when playing live, other than to mute the bass when necessary.
My 4 string Ibby Mezzo is currently getting modded with the EMG-X PJ set and I did think about a 3 way switch as the ABC active balance was a nightmare to find anywhere in Europe. But I found one so it will have a sensible Bass / Treble stack and the ABC balance.
I'm planning it to be my main recording bass so hopefully it will be nice and quiet and easy to play with 32 inch scale.
That would cover a lot of bas(s)es .
Yamaha BB and Sadowsky hybrids are good too.
Mine's a VM4, so a 'reverse' P pickup with a MM-esque humbucker. The MM pickup doesn't really do Stingray sounds as it's in the wrong position (too near the bridge) but I just think of it as a beefed-up Jazz bass bridge pickup that sounds great blended with the P pickup. Actually prefer mine in passive mode but the active is nice to have and it switches in and out on a push-pull pot (also good to know that you can safely use passive mode if the battery dies!).
Amazing playability, which is something just about every Sandberg owner seems to experience. The newer "California II" shape isn't everyone's cup of tea but I like it and they are generally a bit lighter than the older ones and have a lovely compact feel that makes them feel even easier to play.
I love the bass in the link below in terms of the look, but it is just too much. Seems they are charging a premium over similar aged and specced guitars.
https://reverb.com/uk/p/fender-precision-bass-1970-1983?hfid=38562491&utm_campaign=INTL-GB-Shop_unpaid&utm_medium=cpc&utm_source=google
