FS: ESP Custom Labs Strat pickups - New in Box
Ron Ellis '64 Strat pickup Set - Brand New
Bought to create options for a Masterbuilt strat, but unused. Wires are unsoldered, original length.
£763 shipped in the UK - SOLD
ESP Custom Labs Stratocaster Bridge Pickup CL-P-S-2 - New in Box
Bought to create options for a Masterbuilt strat, connected for 10 minutes home testing, then returned to box.
It accepts conventional Fender sized pickup covers.
Actual DC measurement is 7.21kΩ
From the ESP website:
Magnet Alnico 5
DC resistance value 7.4kΩ
Resonant peak 7.2kHz
Accessories 2 mounting screws, 2 springs
A pick-up with a strong bite that combines delicacy with a strong high mid. From dynamic cutting to solo play, the high expressiveness is attractive.
All ESP Custom Lab pickups have the following special earthing. The coil and bobbin are wrapped in copper foil to catch external noise. The noise signal is output by the OFC (oxygen-free copper) cable separately from the hot and cold pickup coils, and is dropped to the ground more quickly and reliably without interfering with the original signal of the pickup.
£139 shipped in the UK
ESP Custom Labs Stratocaster Neck/ Middle Pickup CL-P-S-1 - New in Box
This is a standard polarity, standard wind pickup (which can work in either the neck or middle as ws traditional with early 50s strats). It accepts conventional Fender sized pickup covers.
These sought after pickups sell for £150 each in Japan. The clip of Ramon Goose playing this model of pickup in the neck position of his Navigator Strat is posted above.
This measures 6.21kΩ
Magnet alnico 2
DC resistance value 6.4kΩ
Resonant peak 7.5kHz
A single-coil pickup for Stratocasters that features a light attack feeling that does not require a compressor. The bell sound when mixing is also attractive.
All ESP Custom Lab pickups have the following special earthing.The coil and bobbin are wrapped in copper foil to catch external noise. The noise signal is output by the OFC (oxygen-free copper) cable separately from the hot and cold pickup coils, and is dropped to the ground more quickly and reliably without interfering with the original signal of the pickup.
Currently in the £200s on eBay.
[admin edit - ebay link removed]
Bandcamp
