Do you use the 'right' guitars for covers?
13»
  • ESBlondeESBlonde Frets: 3589
    Roland said:
    Let’s add acoustic guitars to the discussion.
    In our covers set 20% of the songs are driven by acoustic guitar. The last time I tried to play an acoustic guitar at a gig it was feedback mayhem. Nowadays I use an acoustic simulation.
    Who takes an acoustic to a gig because it’s the “right” guitar?
    I take an acoustic to country band gigs. The Atkin with a mic/PU combination into a mesa Rosetta preamp to tame any howling and give a full tone. Sometimes I need to back off the low end to give the bass some space and punch through.
    Me, though only for Django gigs.
    I put a bit of wobbly chorus on my electric to "emulate" a 12-string
    Feedback
  • Danny1969Danny1969 Frets: 10411
    I don't do this now but this was the guitars me and the other guitarist used for a couple of years before we slimmed it down to 2 guitars each.
    This is what I used for what songs
    Ibanez neck mahogany guitar with locking trem - used on all the heavy stuff like Van Halen
    Gibson 1986 LP custom - used as main guitar
    White Fender Strat - fitted with 12's and used only for U2 songs
    Red Strat - used for Sultans of Swing
    Gibson SG Double neck -  used for Hotel California and Dead or Alive
    Then the other guitarist used
    Gretch Bono sig guitar
    Unknown Tele with humbuckers
    Gibson J200 acoustic
    Taylour 12 string acoustic.
    There is  \ was never any feedback problems with the acoustics, despite having huge amounts of them sent to the floor wedges. And he plays at a quite frankly mental stage volume
    I remember it used to take 3 trips just to get the guitars in the venue from the van, what were we thinking :)
    1reaction image LOL 3reaction image Wow! 2reaction image Wisdom
  • koneguitaristkoneguitarist Frets: 4138
    No just right hands.
  • mark123mark123 Frets: 1325
    Doesn't matter 1 jot !
    Can you see Julie and Sandra pissed last orders " eeeh i'm not dancing to dakota, he's playing a les paul with marshall stack and i know kelly plays a 82 sg standard with 9'sthrough a matchless valve amp .
  • steven70steven70 Frets: 1263
    How about playing slide?
    Best I can come up with is arranging the set to have a 'slide/open tuning' section.
    The Variax (mentioned above) is interesting...didn't know they could do that.
    Any other ideas?
  • GrangousierGrangousier Frets: 2637
    Rowby1 said:
    I rotate all my guitars
  • MusicwolfMusicwolf Frets: 3655
    I used a Variax for a while (JTV 69S).  I had it paired with a Line6 POD HD500 which meant that I could select the guitar model directly from the pedal board.
    It weighed a bloody ton and it didn't sound as good as my regular Strat (nor play as nicely).
  • slackerslacker Frets: 2238
    Any other ideas?
    I've often taken a second guitar to a gig. If I need slide tuning the spare is open tuning. It can be returned to normal if needed. I don't use heavy gauge strings or a rained action for slide. Also I can play a lot of slide stuff in normal tuning.
    I have a mate who used a Les Paul into a TSL in a duo. The guy in our band uses a LP Deluxe into a JCM900.
    For everything. Nobody appears to have complained yet.
  • rockmonsterrockmonster Frets: 838
    No 2 guitars. One PRS for tuning stability and which ever other one I fancy taking along (second PRS or tele/HSS strat)
  • FezFez Frets: 524
    I usually take 2 guitars if we play 2 sets I often change at half time so strat first half L.P. or PRS second half. That way both get an airing and I have a spare if needed. If I need to play Sharp dressed man on a sss strat that is what my Fallout cloud is for.
    Don't touch that dial.
  • Alex335Alex335 Frets: 121
    I think the right tone is more important than the right guitar, obviously the choice of guitar is an important factor in that but if you can get convincing tones to cover the whole set with one guitar i'd go for that.  usually a Tele as they cover so much ground sonically
    unfortunately there are plenty of bands out there using the right kit to create the wrong tone
  • rich75rich75 Frets: 36
    Definitely this^
    I used to keep changing guitars through the course of a set and ended up realising that it's more important to keep the set flowing and minimise delays/interruptions for guitar changes.
    I tend to take two guitars with me now, a Les Paul which is the "main" guitar, and an Ibanez AZ as a back up and to use if the song requires a trem.
    I'm playing through a Helix so it's easy enough to modify the tones to suit different guitars if required, although I don't actually use different patches for different guitars. I'm also starting to belatedly realise I'm probably the only one who really notices (or cares about) the difference between the guitars anyway!
    I've definitely come across people who seem to use their eyes more than their ears when it comes to gear choices. I remember someone I was in a band with once doing a quite ropey sounding version of sweet child o mine. The tone just sounded completely wrong but he was convinced it must be right solely because he was using a Les Paul through a Marshall.
