SOLD: Morgan AC20 Deluxe Head and matching 1x12 Cab in Driftwood finish
FS/FT: Morgan AC20 Deluxe Head and matching 1x12 Cab in Driftwood
USA built 20w hand wired AC style amp Head and matching 1x12 Cabinet in Driftwood finish.
Inspired by the classic British valve amps of the early 1960's.
Switchable preamp section between EF86 and 12AX7 tubes and Power scaling.
Joe Morgan's own blurb:
The Morgan AC20 Deluxe is a deceptively simple amplifier that is capable of producing a myriad of early 60s British tones but that is just the beginning. The switchable EF86 tube helps to make the range of tones from the cleanest of EL84 chime to ferocious high gain growl. The power level control allows you to dial in just the right amount of volume without sacrificing your tone the way some master volumes do. The AC20 Deluxe was created to solve modern guitar player amplifier issues with the ability to stay true to vintage tonality. It is equally at home in the studio or on the stage. It can be seen on the stages of superstars like Jeff Tweedy, Tim McGraw, The Band Perry, Taio Cruz and with ToshiYanagi on Jimmy Kimmel Live. Plug into the AC20 Deluxe and you will instantly notice the familiar chime and compression of the Class A EL84 driven output section. The amplifier’s extreme touch-sensitivity will allow you to coax clean tones even at the highest of gain settings. To quote Keith Armstrong (Chief Engineer at Mix LA) “It is impossible to get a bad sound out of this amp!”
PRODUCT SPECS
Power: ¼ - 20w variable (tube)
Three modes – Normal/Brilliant/EF86
2x EL-84 power tubes
2x 12AX7 preamp tubes
1x EF86
Global Cut – removes high frequencies from the power section
Bright and Bass Cut switch
2x8 ohm 1x16 ohm outputs
Custom USA made Mercury Magnetics transformers
Switchable EF86/12AX7
Handcrafted in the USA
Handwired in the U.S.A.
PRODUCT DIMENSIONS
Dimensions: 7.5" (D) x 17" (W) x 9.75" (H)
Weight: 25 lb.
Pristine condition.
£1850.00
Trade wise Looking for:
2018 Gibson Custom Shop ES335 Anchor Stud
PRS DGT with moons.
Lazy J20
Collection or meet up within reasonable distance, Shropshire based.
Thanks, Paul
Your YouTube links aren't working because you edited the post - might want to redo them.
GLWTS.
