Apart from clamping the strings (I put the strong through the machine head and just clip the ends of the wound strings) I genuinely don't find a Floyd any harder to restring than any other bridge that floats.
If the bridge balanced before you removed the strings, and assuming they're the same brand & guage it will return to that same balance point.
I tune the low E first to take up the tension, the the others and one the top E is in tune just go down through to the low E retuning each string a few times, give them a good old stretch, a final tune and job done.
