Feline Guitars in "not Les Paul shaped" guitar shock
13»
  • FelineGuitarsFelineGuitars Frets: 11597
    sev112 said:
    @FelineGuitars might I ask why some of your s shapes have a “neck plate” and some just have 4 individual bolts ?
    We tend to make the all access by choice.
    The Yellow strat was a Warmoth body we got from someone that we turned into a project, and the two left handed necks were for a big project that had vintage specs for a Hendrix tribute that didn't materialise so we decided to make a couple of vintage spec s-types in that flavour anyway.
    We've kind of always made a few S -types over the years - this one is from 2006
  • robertyroberty Frets: 10893
    Chanced upon this other feline strat today
    And in case we forgot to make something left handed we went for a pair of late 60s inspired strats that we called the Woodstock model
    With BKP Mother's Milk pickups, Fender tuners , and traditional heel and a Fatcat Components Double Whammy Bridge with Highwood saddles. The mirror image logo was intentional - I remember seeing it on a lefty strat before and thinking it was a cool touch, also we did the same for our art and graphics guy's guitars (he is also a Southpaw)
    Thinking Olympic White for this one
    And maybe a 3 tone sunburst for this one
    Here it is painted
    edited October 2021 tFB Trader
    Today's throwback is the Feline Rastacaster
    Swamp ash body and a maple /rosewood neck with Dunlop 6100 frets
    Gotoh Wilkinson tremolo and Sperzel tuners
    A fab stain and paint job by the sadly deceased Mick Dearing
    A fairly standard non pickguard H/S/S layout with a couple of twists
    Pickups were Seymour Duncan TB59 and SSL1 vintage strat pickups
    The 3 switches were all 3 position with off in the central position
    The Humbucker was full series in one position and split in the other
    The single coils are able to be in phase or out of phase depending on which way you throw the switch
    The tone control was different as it had a tone coil choke in the circuit giving an almost wah like filtering  and a push/pull on the tone control let you have that choke either in series or parallel with the tone capacitor
    So a wide range of tones could be had from stock sound to mid focussed to scooped and even scratchy sounds like through a small transistor radio.
  • sev112sev112 Frets: 2769
    Wow, great look!
    How do you get such precise lines in those colour changes ?  Is it just masking tape, or is there some other magic involved.   I’d imagine if it was anything like my attempts at painting things with masking tape, loads of paint / stain would seep under !
    sev112 said:
    Wow, great look!
    That was down to the paint finisher we used at the time : Mick Dering of Classic Finishes, who sadly passed away
    I imagine he did a clear basecoat of polyester, and then some very careful masking  and spraying stain
    But as you say - no bleed lines at all ....simply superb!
    Just completed a build for a long term customer
    Swamp ash body and 3 piece quartersawn maple neck
    BKP VH2 and Dimarzio Area 61 stacked single coils
    Hipshot contour tremolo and Graphech ratio locking tuners
    All access neck joint and brass insert /machine bolt fixings
    0reaction image LOL 13reaction image Wow! 0reaction image Wisdom
    https://clips.twitch.tv/OddProductiveLaptopRitzMitz-WRytYQUEFTIOZ17j
    A great clip extract  from Martin Mickels twitch livestream using our Feline Guitars S type with roasted maple neck
  • Philly_QPhilly_Q Frets: 22945
    Apologies for veering off topic, but John Gatto of the Good Rats used to play a cat-shaped "John the Cat" guitar.  In fact he had several of them.
    And this chap was pictured with one as well:
  • SporkySporky Frets: 28381
    Any offset plans? Perhaps the Caracal?
    edited September 2022 tFB Trader
    Have done a couple and there may be a couple more in the pipeline for the next year
    and yes the logos are deliberately reversed out on the next two - customer is a graphic designer and wanted it that way, and designed how it should be
    and he had a strat too....
  • grungebobgrungebob Frets: 3331
    That blue one is amazing.
    Would look cool with raised Center block like a firebird to match the headstock with split pickguard
    Here is one we just finished for a customer in Scotland
    Colour is the colour that Lamborghini use on the Aventador sportscar
    Pickups are Oil City Blackbirds and a Sycorax in the middle
    Trem system used is one of our favourites: Hipshot Contour system
    The trem has a Tremol-no  fitted and has an access hole via the backplate
    Schaller locking tuners  do the tuning duties
    edited May 2023 tFB Trader
    Here we have a pair of similar spec builds:
    Contoured alder body, roasted flame maple necks (ivoroid bound and with luminlay side dots).
    Dunlop 6155 frets, Earvana nuts
    Graphtech Ratio tuners and Grainger hardtail bridges
    Elecs are Bare Knuckle via CTS pots and a freeway 10 position switch
    Mothers milk set on the s-type one
    Irish tour on the Tabby hybrid one
    S-type hardtail
    Tabby Hybrid hardtail
    This Lake Placid Blue beast ready to go out to a customer - this is his second S type from us
    and this Candy apple red one has a 3 piece neck with a lean-back headstock and will be available to buy
  • prowlaprowla Frets: 4928
    On reading the thread title, I just knew it had to be a Strat shaped guitar!
    edited February 4 tFB Trader
    Interesting how nitro finishes just age and go a bit relic'd while you are not looking at them
    We had a couple of our S-types finished in nitro with the aim in offering a naturally aging and relic'd finish. We expected a little aging but this has gone to town.
    So brand new back from the paintshop we photographed it
    and a couple of years later sat in it's case - gone nicely aged
    Still in the shop but I may have to take new photos to show the progress  of the aging
  • SchnozzSchnozz Frets: 1949
    I'd just like to say that the Burgundy Lion SC Cub is wonderful. I like that the grain on the above follows the contours of the pickguard too.
  • rlwrlw Frets: 4703
    Apropos the thread title, I fail to understand why anyone would want a guitar that wasn't LP shaped.
