Mix Challenge - The Flame
  • poopotpoopot Frets: 9099
    They should all line up.
    my lad has imported into ableton ok and I know @bezzer uses cuebase and has had no problem…
    set your project to 75bpm and 48k and ignore all the markers and crap that logic sticks in…
  • andy_kandy_k Frets: 818
    I have my project open, looking at drums, overheads, room and crush all line up perfect, as they should, everything else corresponds.
    item properties reveal a single cue at 001, and tempo set to 120.
    All tracks show a tempo imprint of 120, so I see no reason for the weird offsets you are showing, OH, room and crush are all at different points in the timeline, and they are simply audio with silence at the beginning.
    I have all tracks imported into group folders, so maybe, seeing as you have only just started the project, I would try again, taking care to ignore ANY tempo or clock info on import.
    I have never used Cubase, so maybe there is a setting doing it by default, but I can't see any cues at all in the drums, apart from start and tempo 120??
    I think it might be something to do with Logic beat mapping, which is being included as data which is not being translated properly??
    Maybe.
    I'm not starting to mix yet, but let me know if you find out the problem at your end, I'm assuming mine is good to go.
    edited October 2021
    Not sure why there is an issue…
    Everything should line up (that’s just drums)
    also not sure why you’re seeing 120bpm
    Meta links being added to the export, check an individual file properties, a bit like the info added to an mp3.
  • SiejenSiejen Frets: 33
    Thanks to @poopot ;and @andy_k ;I ran the ‘proper’ cubase import through the pool, rather than just dropping them on the grid, and everything is resolved and lines up nicely.
    Lesson for next time!!
  • BezzerBezzer Frets: 586
    Not sure how good it is but I've run out of time until ... January ... so it'll have to do!
    edited November 2021
    Been quite awhile since I last joined but I'll give this a crack please! Got a new workflow which I'd like to try out.
    Think I will try mixing without referencing their final song at all. Will be interesting to see how different my output will be.
  • Please may I join in the fun?
    How’s everyone getting on? Seems a bit quiet!!!! Last week n all that!.
    Last day for entries
    Is anyone going to cross the finish tonight?
    if no, I’m not going to bother with another one after this… it takes a lot of time and effort to bounce and organise all the tracks, upload etc and send the link….
    So I win, right?
    Go me, I am the bestest!
    Sorry, life got in the way, appreciate your efforts @poopot .
    Entry closed… @Bezzer won!…
    Sorry poopot. Only got as far as some rough levelling and some other projects took my time. Appreciate you organising this.
    Sorry Stuart, like Andy (and after all the initial fun of setting everything up) life got in the way badly.
    Also as Andy said, I appreciate all your efforts on these.
    Iain
