Given that we don't want to get close to Martin prices, that only leaves the made-in-China stuff, and a few others of similar ilk. As always, the answer is to play as many as you can and see what you like. But I would start with Sigma. Sigma's management seems to keep its finger on the pulse and all the ones I've played have been good examples of their kind.
Good shout. A friend of mine has an Aria D-28-a-like and it's an absolute cannon.
The anniversary models ave nitrocellulose lacquer. I believe they use an ultraviolet-cured lacquer for the upper range guitars of style 40 and above and very thinly applied polyurethane lacquer for styles lower than that. The lower range guitars use man-made "Micarta" for the fretboards. To me it looks and feels very much like dense unfigured ebony, but I have no idea whether it behaves like wood during a refret. I'm pretty sure it won't affect the tone of the guitar in any perceptible way to the human ear when compared with rosewood or real ebony. Most of the lower range guitars also use a wood called Tilia for the backs and sides. This is generally referred to as Lime (not the citrus tree) or Basswood. On my dark sunburst OM sized guitar with Tilia back and sides the wood is dark and as a nice figuring that resembles rosewood to some extent and certainly doesn't look out of place on a good quality guitar.
Sigma Model Numbers Explained (valid at 2015) Starting from Left to Right
Wood quality:
S = All-solid model Solid top, solid back and sides
Nothing = laminated
Body size:
D = Dreadnought
OM = Orchestra Model 1-3/4" nut width
000 = Auditorium 1-11/16" nut width
00 = Small body
G = Grand OM
J = Jumbo
T = Travel Guitar
B = Bass
C = Classical Guitar
U = Ukulele
Material:
MR = Madagascar Rosewood
R = Indian Rosewood
M = Mahogany
T = Tilia (Lime or basswood)
K = Koa
A = Maple
Special Features:
C = Cutaway
E = Electric pickup
12 = 12-String
Series:
SE = SE-Series Satin finish, Sigma electronics (not mentioned in model name, eg. DME)
ST = ST-Series Satin finish
1ST = 1-Series Gloss finish
4 = 4-Series Vintage toner
15 = 15-Series All-Mahogany
18 - 45 = Ornamentation level Standard series, Vintage series
Features:
H = Herringbone
V = Vintage style
S = Short neck (Neck-body joint at 12th fret rather than 14th)
5 = 5-String bass
F = Fretless
E = Electronics
YEARS = Anniversary model
LE = Limited Edition
L = Lefthand
Finish:
- = Natural finish
+ = ??? (possibly refers to "Micarta" fretboard)
SB = Sunburst
BR = Brownburst
BK = Black
SDR-28 - RRP $1,210 on USA market just over £900 here, but reduced at the moment in most stores.
(Sitka Spruce top, solid Indian Rosewood back and sides, mahogany neck, ebony fingerboard and bridge, bone nut and saddle, 44.5mm nut width, Grover tuners, tinted "aged" lacquer, with softshell case).
https://www.sigma-guitars.com/guitars/standard-series/sdr-28/
SOMR-28 - The OM sized/shaped version of the above dreadnought for about the same price.
https://www.sigma-guitars.com/guitars/standard-series/somr-28/
It then drops to the "Tilia" and "Micarta" versions in the "28" styling:
DT-28H - RRP in USA market $730:
https://www.sigma-guitars.com/guitars/standard-series/dt-28h/
DTC-28HE - RRP in USA 930 - Cutaway electric version of above:
https://www.sigma-guitars.com/guitars/standard-series/dtc-28he/
000T-28S - RRP in USA $790 probably around £600 here - 000-12th fret sized/shaped version of the above
https://www.sigma-guitars.com/guitars/standard-series/000t-28s/
If you don't want to pin yourself down to ONLY the Martin type of "28" styling, there are a lot more dreadnoughts to consider in the Sigma range and they are widely available fromUK retailers, although supply chain issues may mean the stores don't have all the models to try.
The 2 digit models are only solid tops.
Recording King as well, I'm fairly sure they are built in the same factory as Sigma guitars. I think the Red Spruce RK's are very good value for what they are but I'd try one in a shop first.
That said, here are some guitars that you may find within your budget that have a similar makeup to a D28.
I've added comments to some of them (cos that's what we do on forums, isn't it? However, YMMV)
Sigma SDR28 (Tried one in Merchant City Music and it was totally dead. Sounded muffled and quiet. None of the richness and vibrancy you'd hope for in a Rosewood dread. They're also made in the Cort factory in China which may or may not present an issue for you).
Recording King RD328. Haven't tried one, but Patrick Lundgren and JP Cormier make them sound amazing.
Yamaha LL16. This isn't a straight copy of a D28, but the value is incredible, and they do produce the odd example that is a total cannon (check JP Cormier's review).
Do you have a source for this info I could look at? Cos anything built in the Cort factory is a "no go" for me.
