Acoustic Guitar Demos - Standard Tuning Please
  • jaymenonjaymenon Frets: 829
    I was surprised to find out that - paradoxically - when your string gauge is heavier, you can take the action much lower in terms of
    - arc relief
    - nut slot height &
    - saddle height
    since for any given volume, the actual excursion / vibration of the strings is less - with less tendency to crash into the frets and cause buzzing.
    So oddly, heaver gauge strings can be no harder to play.
    Until you try string bending.
  • TanninTannin Frets: 5501
    ^ Interesting. And makes sense.
  • bertiebertie Frets: 13569
    edited December 2021
    if you "noodle" with drop-d purely for the low D,  little trick is to capo the top 5 at the second fret............gives drop D while maintaining "non drop" fretted notes  (Uriah Heep - Wizard for example)
