FS: TC Electronic Nova Drive Overdrive Distortion Tubescreamer pedal, new. SOLD
Surfmonkey77Surfmonkey77 Frets: 274
edited August 2014 in FX £
Just got this free with my G System but it isn't something I will use, hence it must go! Brand new, only opened to look at.
£100 posted
  • IamnobodyIamnobody Frets: 6916
    Interesting could this be setup so you could have a 3 basic drives at the click of a foot switch? For example, preset 1 rhythm crunch, preset 2 lead, preset 3 solo.
    I realise you could probably achieve this with drive, distortion and combined but it might get a bit messy...
    I might well be up for buying - I'll have a look at some reviews.
    Previously known as stevebrum
  • John_PJohn_P Frets: 2753
    I used to gig one and really like the sound - very flexible with the ability to stack the two drive types.
    You could do just what you describe with the different sounds but to get from 3 solo back to 1 rhythm crunch would take two clicks...   if that's not an issue then it could be perfect for giving you lots of drive options.    I'm half tempted to get another for the way they integrate with the Gsystem via midi.
  • Thanks John...... I can include the Y midi cable to use with the G system if it helps?
  • Any takers on this fine Friday?
  • £90 delivered.
  • bump
