Most of the time, I won't need to refer to it but every so often there is a song that just won't stick, or I get a moment where I totally go blank on a lyric I would normally remember 999 times out of 1000.
Also, being a wedding band, we get lots of first dance requests and often it will be a song I have never played before. Damn right I am having the cheat sheet in front of me when we play that.
It's false bravado not to.
The trick, of course, is to make sure you keep looking up, that you engage with the crowd as much as you can with eye contact.
I do find it odd, however, how some songs get stuck in my head and I can sing and play them from muscle memory, and other songs, seemingly at random, just will not stick. One example being Mr Brightside. The second part of the verse (which, annoyingly is repeated again as the song only has one verse, really) ...I just cannot remember what the first line of the lyric is. Must have played the song 500+ times now.. And I am the kind of person who listens out for lyrics and finds them easy to remember usually. Don't know what it is about that particular lyric that just isn't memorable for me!
Another tip: write out an annotated setlist, with the key signatures next to the titles, and maybe the first line of lyrics, or that tricky bridge chord sequence. So at a glance as you start the tune there's a bit of a prompt to get you started but you're not glued to it.
Otherwise though, @fastonebaz is right, just repetition. Singing along in the car, air guitar on the train etc. Supposedly actors learn their lines last thing at night so their brain can process it while they sleep too.
Oh, and once you've done a few, it gets easier, like you're training up the bit of your brain that deals with memorizing tunes.
You don't need to remember chords really. If I've heard a song a few times I know the chords. I can hear the intervals. Once you can hear the intervals you can play a basic song in any key just by knowing your scales and intervals. This not only means you don't need to spend time learning a song, it also means you can play the song in any key. This Also applies to riffs, which when you think about it are really just intervals from chords played as single notes or double stops. Some that rely heavily on open strings can be a bitch to transpose but in general most can be moved key wise.
Lyrics can be tricky. Generally if i can remember the first line the rest comes for some reason. Some of my friends use iPads, one guy has a fake monitor with an iPad Pro in it rather than the speaker. Then he has a BT page scroll pedal. I think that's the better way to do it rather than an iPad on a stand.
It's amazing what you can get away with though. For years I've been singing "There's a crowd of young boys fooling around in the corner, drunk and dressed in some lyrics I never bothered to learn" .... and no ones ever mentioned it.
I used to play in a hair metal band and the singer got so sick of singing Animal by Def Leppard he changed the opening lyrices from Wild ride to Head Lice or Fried rice or some similar shit and no one noticed that either.
There's no substitute for knowing it inside out. Eventually it just soaks in.
Our main singer has a mini-pad thing on a holder on her mic stand which isn't too obtrusive. Our previous singer was Mrs. Memory Woman - she knew 'em all by heart.
Personally not a fan of music stands for club / pub gigs for a variety of reasons - primarily I think they just look wrong.
I think maybe I've got a memory problem - too much smoking weed in my earlier years. It's odd though, as I can remember lyrics, melodies and guitar solos (to sing) from songs years old that I haven't heard for ages, but I can't remember chords.
Offset "(Emp) - a little heavy on the hyperbole."
By and large if I worked something out by ear I'd remember it better. This includes lyrics, printing some words off the internet and hoping they stick didn't work. Sit down with pen and paper and a recording and work out the structure and every word. If I was then going to learn the song on guitar it meant I had listened to it closely ten times already so it helped that process as well. Of course some lyric sites are just wrong anyway.
Oddly enough it's also a reason for more pedals - having a slightly different sound for a song helps trigger the memory. I didn't have a lot of scope for that but say one song in the set used a tremolo pedal and one song used a long delay I'd remember the guitar parts more easily than for others.
To memorise I think about song structure, chord sequences and any extra bars, riffs, and the start of any solos. Then practice.
When it comes to live performance I confess to using an iPad. I use it for the set list, tempo click, controlling the mixer, and a crutch if I forget the chords.
I'm not saying someone could chart out Bohemian Rhapsody or Mr Blue Sky in their heads on the first listen but they certainly could for 99% of pub stuff like Ed Sheeran, Killers, The Weekend, Stereophonics etc.
Putting a bit of effort into learning theory has actually saved me hours of working stuff out. If something sounds normal and not jazzy or edgy then it's diatonic. That straight away tells you the 4 or 5 chords that are used and you immediately know what chords aren't used ... because if they were used it wouldn't sound diatonic.
You know like some people go Start, Settings, Devices, then click Device manager and some people just right click the start button to get Device manager .... it's literally that. Those little short cuts you learn to get around the OS save you countless hours over the years and a learning a little bit of theory does exactly that too.
Not until I get it right, but until I can't get it wrong.
Even for jazz band gigs where it's expected for the players to have the sheet music I learn it so I don't need it - including any repeats that might change on the fly depending on how many soloists want to take a turn.
Only ever play originals in a mediocre band, only ever be good enough for support slots so you only ever have to worry about learning enough material to fill 30 minutes max . On the rare off chance you get a headline slot, just extend the solos of the six songs you were going to do by 3 minutes each. This ensures you won't get asked for another headline slot and normality will resume.
Works for me.
Then there are other songs where I immediately know I'm going to have to get a pen and paper and have one hand on the space bar - the handful of genuinely brilliant musicians I've worked with can blitz through those like I can with a George Ezra song.
If you have to read the lyrics they need to be easy, a wordy song like feel it still by Portugal the man is really difficult to read. You have to learn it. I haven't.
you wouldn’t go to the theatre and expect to see the actors carrying around the script!…
