Check with the desk graphic eq both on and off (if there is one and make sure ot looks like a mild smile). And also the effects that are running, again both on and off. Sometimes you can fall victim to a singer that has fiddled with the pa to compensate for the fact they can't actually sing.
Also, ask the band to turn down (a lot!). It is a rehearsal and if the speakers are pointing at your guitar you can only go so loud. If they refuse, at least you will know up front there is no point to all the usual lenghthy 'will we get signed' phone calls with the drummer, etc...lol.
If the gain is set correctly and the speakers are in a reasonable position it should be pretty much plug and play - the OP needs to check those and if it sounds poor then it's the cable or a fault in the pickup. Shouldn't take more than a few mins to work out which...
Or it could be a malfunctioning component. I think the advice in this thread has been balanced.
