All sold: Two Notes Cab M (+) and Suhr Reactive Load
pickergpickerg Frets: 30
edited August 2022 in Studio & Rec £
Up for sale is my Suhr Reactive load. Info from Suhr:
The Suhr Reactive Load delivers a simple solution to capture all of the warmth and dynamics of your sound, without the hassle of mic'ing a speaker cabinet during a live or recorded performance.
The Reactive Load takes the place of your speaker cabinet in your signal chain. It provides an 8Ω load for your tube amplifier (maximum 100 watts), and produces a balanced and unbalanced signal that interfaces with recording devices, effects, and power amplifiers.
Couple of scratches but works perfectly. Don't have original box but can be packaged up for posting.  £260 posted SOLD
  • WyzardWyzard Frets: 55
    Hi, PM sent.....
  • pickergpickerg Frets: 30
    edited May 2022
    Also got a Two Notes Torpedo Cab M, which with firmware was upgraded to full Cab M + spec, so you can use it without an amp with the built in clean amp simulator.  Info from Two Notes:
    Lugging around heavy speaker cabs is a price we've had to pay for pure guitar tone - up until now. The Torpedo C.A.B. M+ negates our cab mic'ing frustrations with an intuitive, quick-dial solution. Customise your sound from a choice of 32 pre-loaded virtual cabs, eight microphones and 12 room options. Load up your own cabinet IRs thanks to 512 additional memory slots or thousands onto the included memory card. Blend two IRs with minimum latency. Bring any music style to life.
    Control all parameters from the bright-lit C.A.B. M+ screen or use the excellent Torpedo remote software on your smartphone or PC. Dial in your tone without moving an inch.
    Not enough space at home? Physical cabinets too loud? The C.A.B. M+ has a headphones output for quiet sessions and aux in to play along with backing tracks. Complete with ground lift switch to eliminate electrical interference.
    Great condition with Velcro on the underside. £165 £150 posted
    Bump for Cab M +
     Still around, make an offer if you are interested…
  • robmac5150robmac5150 Frets: 184
    Pm incoming
  • EvanEvan Frets: 326
    Pm’d
