What came 1st - the (C) major scale or the piano keyboard ?
  • The keyboard layout is actually 200-300 years older than the piano. Glancing at the Wikipedia article it seems that it initially varied depending on the notes used in the music at the time and the instruments capabilities. Could see anything on how we wound up with a standard layout
    https://en.wikipedia.org/wiki/Musical_keyboard
  • GoFishGoFish Frets: 1431
    Tannin said:
    @sev112 Redit has an excellent set of articles covering these very questions. Let's see if I can find it ... hmmm ... not sure if this is what I'm looking for: https://www.reddit.com/r/musictheory/wiki/index#wiki_history_of_music_theory_questions ;
    ... Yep. That looks like the stuff I remember. Poke around and you'll find answers to most of those questions. Redit can be a bit of a flea pit, but the music theory section can be very good.
    Bonza! Thank you =)
  • vizviz Frets: 10709
    edited March 2022
    According to Early Keyboard Instruments, this is the earliest surviving music written for keyboard - 1320 - but it wasn’t the current configuration of keyboard. Keyboards existed before then, it’s just that the notated music from before then hasn’t survived. And no 15th century keyboard music has survived, oddly.
    https://i.imgur.com/AslQaG3.jpg
    In terms of instruments, the hydraulic organ was around as far back as 300BC, and the pneumatic organ was introduced (actually re-introduced apparently) to the West in 756AD. They also didn’t look the same as today. The Winchester organ in around 1000 had a diatonic scale with an extra Bb.
    And according to English Keyboard Music, there is this key ( )section here; the extract at the top is from 1519. The 27 keys refered to are mainly white; there were some black keys inserted at the bottom, but these were 4ths or 3rds apart, not semitones. So the current system was still not around by 1519.
    https://i.imgur.com/Q5cUHqW.jpg
    It was well after that that the harpsichord and associated instruments came into existence, followed by the fortepiano, then the pianoforte.
  • thingthing Frets: 469
    edited May 2022
    We have some fascinating stuff in the library at Lincoln Cathedral. We've had organs here since at least 1310 cos we have the invoice for a guy who used to clean the bellows. So I'm guessing they were here a while before that. We also have some early plainsong music, manuscript of course and loads of manuscript Byrd stuff cos he used to live here and was the organist for a bit.
    The history of keyboards is far too dense to go into here but it's good reading if you are into that sort of thing. Keyboards with quarter tones instead of the modern half tone and all sorts of weird shitness. The history of tempered tuning is worth a book in itself.
    Incidentally, pub quiz trivia, we  have music books that have the words and music printed at four right angles on the same page. This was so that singers could stand around a table and see the music hence the expression 'Singing from the same hymn book'.
    Every day is a learning day.
    This is absurd.  You don’t know what you’re talking about.  It warrants combat.
    0reaction image LOL 3reaction image Wow! 5reaction image Wisdom
  • ToneControlToneControl Frets: 11951
    can you post photos?
  • prowlaprowla Frets: 4934
    Ah, the evocative name of the musical instrument "the piano" sounds so exotic:
    • piano = plane/flat, presumably because the keys are laid out flat
    The full name is pianoforte, which is two verbs stuck together:
    • piano forte = soft + loud
    Incidentally, there is also an Italian phrase "piano piano", which means calm down or take it easy.
  • TanninTannin Frets: 5505
    "Piano piano" = "softly softly" = a 1960s TV show.
    pppppp = the marking on the bassoon part in Tchaikovsky’s 6th symphony. Actually impossible to produce on the bassoon.
  • TeetonetalTeetonetal Frets: 7811
    A early example of passive aggressive behavior?
  • digitalkettledigitalkettle Frets: 3283
    Ppppppassive aggressive ;)
    edited May 2022
    I've looked under every possible permutation on Google and can't believe I cant find any images. Trust me, it does exist, I've held a copy in my sweaty paws! Can't remember whether it was 16C or 17C. I think it was 16th so Tudor and printed so post 1480's for sure.
    @Tone Control: see PM.
    edited May 2022
    Yes! Not uncommon in them days. In Elizabethan times. Normally with a melody and lute line, then the other 3 singers at right angles. John Dowland’s 1st songbook I think, for example, in 1597 or something.
    edited May 2022
    Ah where did you find that!!! Been looking for ages.
    I've got some nice Dowland stuff transcribed for classical. Some of his stuff was a bit dirge like, weird ideas of upbeat music that the Tudors had but some of it is quite lively.
  • GuitarAndy2GuitarAndy2 Frets: 23
    Another good book that you might find interesting is Temperament by Stuart Isacoff, goes into a lot of the origins around different tuning types/styles and the reasoning/historical context behind them.
    Also that book called something like “true temperament and why it killed music and why you should care” or something has loads of good info about the development of Western scales and the tuning thereof.
  • GrangousierGrangousier Frets: 2643
    The other thing is that the fundamental mode (if you're generating a scale from the fifth harmonic), is the Lydian - building the scale by fifths would give you C-G-D-A-E-B-F#, This being the basis of George Russell's frankly inscrutable Lydian Chromatic Concept of Tonal Organisation
  • KDSKDS Frets: 221
    didn't Bach sort this issue out?
  • guitarjack66guitarjack66 Frets: 1884
    Bach to the future?
