Withdrawn
jaymenonjaymenon Frets: 836
edited May 2022 in Parts £
Grover 305 Mid-Size Rotomatics 18:1 3+3 machine heads gold / ebony £47
https://i.imgur.com/PxRu655.jpg
D'Addario EXP17 13-56 Phosphor Bronze 3 sets £20
https://i.imgur.com/EXUy1wk.jpg
Warwick Rockbag £15
Ideal for a POD XT Live size device
https://i.imgur.com/UXjy5aT.jpg
Hardtail Guitarbuild Swamp Ash Strat Body £175
1753g
With matching rosewood veneer pickguard add £20
With loaded pickguard with Kinmans add £200
Recessed Ferrules
Cavities shielded with Graphite paint
https://i.imgur.com/5fVnXwu.jpg
https://i.imgur.com/j44wAAw.jpg
https://i.imgur.com/SEas9DO.jpg
https://i.imgur.com/hzNMjrq.jpg
https://i.imgur.com/u5Rze4y.jpg
Maple Strat neck with Rosewood Scalloped Fingerboard with Wilkinson Vintage Tuners £175
50s / 60s style small headstock
12" radius
Medium Chunky Neck profile:
- 1st Fret: 0.84” (21.34mm)
- 12th Fret: 0.94” (23.88mm)
Frets dressed beautifully and ends rounded at Overwater Basses
Graphtech Nut - slots optimised at Overwater
Rolled 'board edges
Wilkinson Nickel Tuners
https://i.imgur.com/3gSGls1.jpg
https://i.imgur.com/IW7RoCR.jpg
https://i.imgur.com/NcEOSJ6.jpg
https://i.imgur.com/fO38Dxg.jpg
https://i.imgur.com/O1m71VF.jpg
https://i.imgur.com/r1JQwSS.jpg
Solid Ash Guitarbuild Stratocaster Body £380
(Currently attached to a Musikraft neck 12” radius and Stainless Steel frets  - also for sale)
3-Tone Sunburst Nitrocellulose Finish by our Richard Rendall lam62
Super lightweight 1445g (despite being solid construction)
Comprehensively shielded with graphite and foil
Recessed nickel ferrules
With nickel bridge, jack plate and strap buttons
https://i.imgur.com/Iq2On9w.jpg
Tom Anderson Leather £27
Identical leather strap - but without the 'A' £20
Black Poly strap £6
RotoSound Superwound Strap £6
Pickguards
https://i.imgur.com/W8yjZOd.jpg
New Ibanez RG Hxx 1-ply black (Single humbucker) £10
New 1962-1983 style 11 hole Black 3-ply Strat Pickguard with countersunk holes for pickup / switch mounting screws and truss rod notch) £10
Used 1962-1983 style 11 hole White Single ply Strat Pickguard with countersunk holes for pickup / switch mounting screws) £8
Used Modern style 11 hole Black Single ply Strat Pickguard £8
1959-1963 style Tortoiseshell Strat pickguard (neck cutout slightly widened to take a 57mm heel neck) £8
Plectrums
mix and match :-) 40p each.
https://i.imgur.com/hbjhr2B.jpg
Dunlop Jazz III Black 1.0mm Tortex (70)
Black Jazz III XL (18)
Dunlop Jazz III Black (32)
Dunlop Ultex sharp 2.0mm (27)
Dunlop Tortex Purple 1.14mm (and pretty much identical Fender 1.14mm thickness) (30)
Miscellaneous
https://i.imgur.com/X6UXUAU.jpg
Some Stubbys 3.0mm and 2.0mm
Some Dunlop 2mms (see pic)
Rosewood pick £2
WireThing Clear Acrylic Copper Wire Pick £2
