FT Friedman Cali HH Heavy Relic Purple
Not fully decided but I might look to trade my friedman cali (+/- cash depending on opportunity). Hardly played, fantastic guitar.
Looking for Tom Andersons, Strandberg, Musicman JP/majesty
https://imgur.com/a/F2NBu4R
CALI
• Spirit of San Dimas
• Vintage Feel - Modern playability
• Classic Hot Rod Design
ALL FRIEDMAN GUITARS are Custom Ordered and built by hand.
Frets – Jescar FW57110 nickel silver fret wire is used on CALI guitars.
Compound Radius - Grover Jackson invented the compound radius fingerboard (CRF) 35 years ago. The fingerboard geometry is based on a conical shape rather than cylindrical. The significance is tangible and substantial – a 10”-14” compound radius fingerboard allows for maximum playability with no chance of your strings fretting out when bending. The compound radius is time-consuming and laborious to get exactly right, yet worth-it – and featured on every Friedman CALI.
Tight Pocket and Exclusive Zero-Shift Neck Pins - Neck shifting results in incorrect string alignment and is a challenge for many guitars. A tight neck pocket helps, but in-and-of-itself does not eliminate the problem. CALI guitars raise the bar with the exclusive Zero-Shift Neck Pin design; whereby, two military-grade precision steel dowel pins align the body and neck, eliminating shift altogether. The tonal benefit of this connection is a virtual fusion of the body and neck whereby the transference of vibration is maximized.
Tuners and Bridge – The CALI utilizes modern locking tuners and features a German Floyd Rose locking tremolo system.
Plek – Very few boutique builders and many of the giants do not use a PLEK. This German-made device provides the ultimate in fretboard analysis,
fret - leveling and overall setup, and ensures maximum modern playability of all Friedman guitars.
Aged Nitrocellulose Finish - Grover Jackson is one of the few guitar manufacturers in Southern California permitted to spray nitrocellulose lacquer. Friedman guitars wear a thin nitro finish allowing the wood to breathe.
Custom Friedman Pickups – In addition to the Friedman Classic pickup line. The Friedman Classic Single pickups were designed to produce that well-known vintage single coil chime with the ability to cut through the mix. This is combined with Classic+ Humbucker in the bridge position to provide every player with a full tonal palette.
• The Friedman Classic Humbucker is a 'tip-of-the-hat' to the legendary PAF Humbucker... smooth and sweet.
• The "+" in the Friedman Classic+ Humbucker signifies that it has more windings and is hotter than the Classic Humbucker. This gives the pickup a slightly crunchier tone in higher gain environments. This pickup is used in the bridge position of the CALI.
Case included – All Friedman guitars come in a custom G&G case.
