Check around the back. There ought to be a plate providing model number and mains voltage information.
No drawbars, no comment.
I recall that Harry Seven was refurbishing either a Hammond spinet or a Leslie cabinet. I forget what this eventually cost him.
Non-functioning keys and bass pedals may just need their contacts cleaning. This involves opening the case and unhooking all of the keys to access the affected areas. Hopefully, cleaning is enough. Otherwise, some lucky person has to replace the contact strips.
It turns out to be an F2000, made in Japan in the 1970s, an unloved model among organ fans and almost certainly not worth me trying to fix, sadly (not least because I wouldn't really know what I am doing).
Seems such a shame to take it to the tip though.
Or, if you're dumping it, I'll take the Leslie mechanism!
Eqd Speaker Cranker clone
On mine you could cut it out of the main organ still with two sides on, so I kind of just built a plywood frame around it. Had to get help with the electrics but it worked. Heavy, bulky thing, and it took me some time, but it's a great sounding effect, and nice to salvage something.
(Also judging by @robinbowes comment above he will know more about the electrical aspect than me.)
It's pretty simple - basically, just a couple of relays, with caps/diodes for suppression & protection.
R.
