SORTED: humbucker mounting screws+springs + pickup switch
goldtopgoldtop Frets: 6199
edited May 2022 in Parts £
I've no idea where I put mine! :-/
I have a pair of Gibson humbuckers to fit and do not have the two mounting screws and springs that set the height of the pickup above the pickup ring. I need 4 of each.
I also need a Gibson (Switchcraft?) Les Paul pickup selector switch, but it needs to be the shallow/shorter version, as this is for a DC Standard with the thinner body than a single cut LP.
  • CirrusCirrus Frets: 8495
    I've got a switch in my drawer at home, when I get back from work I'll give you a PM with the dimensions. I got it for my Japanese Epi LP but the threaded shaft wasn't *quite* long enough for the routing, so I'll measure that too...
  • goldtopgoldtop Frets: 6199
    Cool - thanks. :)
