Using Garageband on iPhone Live Through Mixer
NorthernStompsNorthernStomps Frets: 398
in Other Instruments tFB Trader
Hi,
If i wanted to connect a USB keyboard to my iPhone to use it to control keys/synths in Garageband, but I also then wanted the sound to come out through a PA Mixer, how can I do that, seeing as though the iPhone (11 in this case) only has 1 I/O?
Ta
Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
  • goldtopgoldtop Frets: 6153
    iRig Keys I/O?
    Or Bluetooth MIDI keyboard to iPhone plus a Lightning to 3.5mm adaptor?
    Or a small interface (Zoom U-44, etc)?
  • personalnadirpersonalnadir Frets: 355
    I'm using an iPad with usb-c, but basically I have a USB-C hub connected to it with an audio interface and midi interface connected to it. I then use AUM to route all the audio inside the iPad. I imagine you'd do something similar except you might need a camera kit if your iPhone has a lightning port. You can probably do away with AUM too, that is probably only necessary if you want to get complicated with lots of audio apps and midi routing going on
  • d8md8m Frets: 2434
    https://www.kingston.com/unitedkingdom/en/memory-card-readers/nucleum-usb-type-c-hub
    I've got one of these, its got a USB-C PD port but also an extra USB-C port which I plug a USB-C to 3.5mm dongle into.
