Looking for advice on amp attenuators with IR capability.
Two options I'm looking at are the UA OX box and the Suhr Reactive Load IR.
Am I right in thinking that the UA is more plug and play but therefore a bit limited and the Suhr more flexible and therefore has the potential to go a bit sideways?
My main issue is one of my amps is 120w (Diezel Dmoll) but the rest are 100w heads or under.
I should be ok running the Dmoll with the Suhr (100w max) if I don't slam it too hard right?
I don't need effects- I have shit loads of those in outboard, pedals and ITB.
Any other options?
Fryette RL IR and Suhr RL IR are the best options. St.Rock React:IR is meant to be really good as well, bonus supporting Ukranian company if you're into that, clocking your avatar!
Many of the loadbox options have flat impedence curves rather than similar to a speaker impedence curve. Suhr's impedence curve is modelled on a Greenback, and Fryette also has a speaker impedence shaped curve but also allows you to adjust it, moving the resonant peak which makes it probably the best option.
When I've seen discussion on this, the feeling is it's definitely better to have a speaker impedence curve (Suhr posted on TGP about it, which is what I'm referencing) than flat.
However there's an interesting video by Rabea trying to match the Neural DSP Soldano plugin to his Soldano amp to get identical as possible tones, where he says he struggled until Neural sent him a custom loadbox they made with a V30 impedence curve, since the Neural plugin is modelled for V30s (Badcat era SLO), which he says helped alot.
I was leaning towards the Suhr.
The Fryette is tricky to get a hold of.
At clean levels, the difference was negligible, but once the wick was turned up, the fixed load still sounded OK but quite flat whereas the reactive had way more bass and treble and generally felt alive.
