Let’s have your overdrive recommendations, then…
  • tone1tone1 Frets: 5170
    Peacekeeper….I absolutely adore it flat out or dialled right back.
  • richman6100richman6100 Frets: 339
    edited June 2022
    Can't go wrong with a Thorpy Peacekeeper or Nordland ODR-C for crunchy rhythm sounds. I have both and they're very versatile as long as you're not after really high gain. They can do everything from smooth (not what you want) to crisp and 'bitey'. Both work well with a range of guitars and Strat/Tele single coils, P90s, Firebird and humbucker pickups in my experience. I'm currently running two Hamstead Artist amps (which are relatively neutral-sounding) and at relatively low volume, so no amp break-up. Another option might be the Thorpy Warthog. At lower drive settings it has more bite than the other two I've mentioned. Cranked, it does RAT sounds and beyond. If I could only have one drive pedal, I'd choose the Warthog without hesitation.
  • louis_LLMlouis_LLM Frets: 126
    Fairfield Barbershop, Greer Tomahawk, Greer Lightspeed, Strymon Deco, JHS Superbolt!
  • monquixotemonquixote Frets: 17637
    Waza Boss Blues Driver is what I use.
    You could also try a Timmy, Nobels ODR, or Bluesbreaker type.
    All good and have their own thing going on.
  • KebabkidKebabkid Frets: 3307
    edited June 2022
    I favour early OCDs (V 1.4) but I've also liked the JHS AT & AT+ and the Catalinbread Formula 5f6 - as it is, it's fine and crunches well but there's an internal dip switch which allows for more Marshallesque rather than Tweed sounds
  • prowlaprowla Frets: 4928
    I've tried a number of Overdrive pedals and TBH I think the first one I had is probably the best - the Boss SD-1.
    ...up until I decided to check out valve ones...
    Right now I like the AMT SS-11B (though it could use a bit of sky blue paint on it).
  • RandallFlaggRandallFlagg Frets: 13941
    edited June 2022
    Seymour Duncan 805
    Crunchy TS style with 3 band EQ
  • JJ72JJ72 Frets: 57
    edited June 2022
    Boss Blues Driver. Cheap, bulletproof, sounds great.
    Definitely this for me too....there's a reason it's on a lot of pros boards.
    Great rhythm sound that stays true to your clean sound. I've had bluesbreaker styles( prince of tone), klon types and ts types and this has always remained on my board while all others have gone.
    Mine is the Keeley version but standard is also great
  • equalsqlequalsql Frets: 6139
    Xotic BB.
  • CirrusCirrus Frets: 8493
    Rat, gain low, filter high. Fulfils all your requirements except the 3 band tone control, but... it's a fantastic low gainer.
  • dilbertdilbert Frets: 203
    Joyo Sweet Baby, TC Spark and Dano TOD, all do it for me.
  • stickyfiddlestickyfiddle Frets: 27106
    I’d try a Timmy/JanRay or BB/KoT type or Peacemaker for that brief.
    Maybe also Lightspeed but I didn’t personally like the one I tried
  • LoobsLoobs Frets: 3832
    I like the Box of Rock, Timmy, OD-3
  • thomasw88thomasw88 Frets: 2328
    Barber gain changer
    Timmy
    Revv g2
    Mad prof sweet honey
    Trex gristle king
    edited June 2022
    Tell you what I didn't like: EQD Plumes...though it seems to sound great for everyone else.
  • Fishboy7Fishboy7 Frets: 2200
    I'm constantly changing my gain pedals but have been enjoying the 1981 DRV and Nordvang Gravity at the moment.
  • Have you tried a modded Blues Driver? Very uncompressed, a lot sweeter after the usual mod kits. If you're handy with a soldering iron you can probably tweak it further to your taste by changing resistor/cap values too B)
    Guitar dealer and G.A.S merchant by day: www.vibrocaster.com
      Blues/rock singer & guitarist by night: www.alexhamiltonguitar.com
  • NeilybobNeilybob Frets: 790
    I'd recommend the
    Ceriatone Horsebreaker Klon/BB but it larger than you specified. I love this pedal.
    Might be worth looking at (though I haven't tried)
    TC Electronics Paul Gilbert Mojo. It has a bass and treble knob and it fits the required size and budget.
    JHS PG-13 Paul Gilbert Overdrive
    MXR iL Torine Overdrive.
    Or if you are feeling flush with £££ then check out the Wampler Pantheon single.
  • andy1839andy1839 Frets: 2197
    I'm loving the 1981 DRV and Venuram ODS-1 and Jan Ray, but into Friedman amps.
    Since getting a Carr Rambler those haven't worked so well.
    The 1981 has a great raspy grind to it, but didn't work so well with the top end in the Carr.
    For the Fender based Carr I've gone with a Suhr Shiba Drive Reloaded Mini and Kingtone Duellist V2 which has a good amount of versatility, although they might be a bit too smooth.
  • TimmyOTimmyO Frets: 7438
    This thread is proof that there is no shortage of very good OD options out there!
    Red ones are better.
