If you were playing this in a band, you might find the guitarist plays the 1-3-5 notes and the bass player plays the low G. On an acoustic, accompanying yourself, you might play this chord in its entirety to get the same musical effect.
C
C major
C over G
C with a G in the bass
C 2nd inversion
Most guitarists would say C over G
(which is also called Dm6)
It's a C/G (or 2nd inversion) because it has the 5th (G) in the bass.
Its a C over G for me.
Ian
A type of Oak?
If there was only that chord and nothing else, it probably has to be assumed G is the root / tonic right? So Gsus4add13 or something is perhaps TECHNICALLY correct. Its been many years since I studied theory mind!
If it forms part of a progression: Gsus4add13, Fmaj, Gmaj then it would make a hell of a lot more sense to spell it as C/G.
I always give the example to students when talking about this kind of thing or F# vs Gb for instance:
It's like THERE and THERE. They both sound exactly the same, but the different spelling makes it mean something entirely different.
____________________
www.adamironside.com
www.youtube.com/Adji87
Nil Satis Nisi Optimum
FWIW, I use the third finger to play the 3rd fret C on the A string when I'm playing a standard C and let it mute the bottom E string so it doesn't ring out on those times when my pick hits it by mistake. Which is just as well, actually... :-)
