My Martin D-16GT action is comfortably under 2mm on the bass side and it doesn't seem unusually low. The Yamaha LL16 looks about the same. Maybe a smidgen higher.
I try to aim for around 2mm low E and 1.75 high E.
You need to be careful, though, especially with Martins. In your quest for lower action you can take away the guitar's fire
But 12th fret action first: 2.8mm and 2.0mm is a little high but not outlandish; @Gandalph's 2.0 and 1.75mm is a bit low but not out of the question.
Correct cutting of the nut slots makes a huge difference. You won't see any difference at all if you measure the 12th fret action, but all the difference in the world if your nut is too high, especially on acoustic where you are more likely to spend more time at the shiny end.
But before either of these, the neck relief curve needs to be right. (Remember, truss rods don't adjust action, they adjust neck relief - not the same thing.)
Finally, acoustic guitars (unlike electrics) have flexible tops. You can't see it with the naked eye, but the top flexes a tiny bit when you fret a chord. On a very stiff-top guitar (e.g., a 1980s Eko 12-string) that flex is insignificant. On a very soft-top instrument (such as ultra-responsive fingerstyle guitars) you can really feel it.
I don't understand the physics of this properly, but I have observed that my two American-style guitars (lightly built and responsive) work best with actions closer to the high end of the normal range while my more robust Australian-style instruments can safely go a little lower. Other factors play a part too: my WA May Maton is a big, bold guitar, well-suited to harder playing and it works best a little higher so that I can hit big notes without buzzing. Good classical guitars have an ultra-light top just barely strong enough to resist the (very low) tension of the nylon strings, and they are normally set up with very high actions. In short, there is no "right", it's all horses for courses.
@Grampa, your best bet is to spend a few pounds (and I do mean just a few). Go to your local luthier or guitar tech and have your guitar set up. In most cases he or she can do everything necessary in about 15 minutes. It might cost £20 or £40 and it can absolutely transform your playing experience.
When I said that there "probably always will be" an issue, there are some manufacturers that have a carved out "plateau" area for the bridge pins that is lower than the surface of the bridge, and this allows for a better angle up to the saddle even if the saddle sits quite low in the slot. I have a small bodied electro-acoustic that I could not lower the saddle any more while keeping a decent breakover angle, so I carved this "plateau" on the bridge and fixed the issue. I don't know why more manufacturers don't do this to their bridges. Here is an example. Slightly blurry, but you should be able to see what I am talking about.
But it does depend on the relief and in some cases how 'loose' the body resonance is, sometimes you just can't get them that low without at least some buzz and rattle.
Bass-side string height at 12th fret: 3/32" (.09375") (2.38 m/m)
Treble-side string height at 12th fret: 2/32" (.0625") (1.58 m/m)
I'd have thought 1.58 a bit low on the treble but there you go.
Sometime "numbers" can be a distraction and take your focus away from the real job of getting used to playing in a different style on a different beast. Bit like people being obsessed with pick up height - a measurement is only someone elses opinion, adjust and do what's best for your ears. Same with action. (tho admittedly there's less room for scope)
FWIW Ive never measured an action height in my life, just try it, feel it, hear it - adjust it if necessary and get on with it
So as rough starting point. Tune to concert pitch . The first fret should be just a bit higher than the second ,when you are fretting the first fret . Set the body fret height to Bass 3.18 treble 2.38 . Adjust as required.
