Looking for string recommendations for this particular guitar, and any further info anyone may have on it.
This is my Flambeau LFW-3 bought in 1985. 645mm scale length, 43mm nut with edgebound fingerboard.
The bridge pulled off about 5 yrs (culprit may have been ducted air heating). I had it repaired by a local shop who refitted it and put two screws though to plates underneath. ( I know, but it was a long time ago, my only guitar at that time, plus I was skint).
Since the bridge repair I stuck with D'addario phosphor bronze 10s for many years then switched to 11s D'add EJ36s - tried DR Rare & liked them.
Still seemed lacking a little, so a couple of months ago I fitted Newtone Heritage 12s as they are low tension and I have been pleased with them, but they are starting to slip tuning so time to replace.
I will add that I use Elixer 12s on a Lowden & like them. (Admittedly, part of that is I hate changing strings - I'd rather play it!)
I keep reading Tannin's string log which is great.
Question is, if the opinion is that it is cedar and walnut(?), what strings would you reckon work best with that combination, bearing in mind I like 12s and low tension would be preferable?
Info so far:
From googling, it seems they made 5 models (LFW-1 to LFW-5) with models 1 to 3 having laminate back & sides, models 4 & 5 being solid. All had solid tops.
The LFW is thought to stand for Lowden Flambeau Western.
I copied a text from another website (can't find it now!) signed by George Lowden :
"I designed the Flambeau guitars in the early
eighties as a favour to the Japanese export company I was working with
for the manufacture of the Lowden guitars. Although I had no control or
oversight of the manufacturing of the Flambeau guitars".
There was an LFW-3 (same as mine) on the Vintage & Rare website stating they were built in the S Yairi workshop in Nagoya, Japan with a cedar top & walnut back & sides, a string-through bridge (like Lowdens), inlaid rosette & pickguard.
Can anyone add to or verify any of this?
Thanks!
DR Sunbeam
La Bella
Martin MA140
Pyramid Western Folk
D'Addario EJ11
You might want to go and have a chat to a luthier about that bridge. My understanding is that anything wooden repaired with screws or bolts is rather likely to play up again because of the concentration of stresses in a small area.
So what strings? Well, what do you want to achieve?
Do you want lower tension and easier fretting? (round cores (but brands vary), Santa Cruz, several others)
More volume? (Dunlop, Sfarzo.)
More treble zing? (brass, almost any brand)
More bass definition? (rough-finish strings like Ernie Ball, Martin, Rotosound)
Longer life? (Elixir and most other coated strings)
Firmer under the right hand and less buzzy but stiffer and harder to fret? (Elixir, John Pierce)
Very firm and very stiff0? (Dunlop)
Country twang? Curt Mangan.
No fretting-hand noise? (Elixir, any flatwound, Martin Monels)
Better balance from string to string? (Depends on which strings need more or less)
Flatter, less dynamic response? (Any nickel alloy string)
And then there are combinations like (just to make one up) lower tension, brighter, lovely soft feel, sweet warm voice (La Bella Golden Bronze - but watch out, they squeal like piglets in a mincer).
Or mellow, very easy on the hands, a bit like a nylon string (GHS silk and bronze)
And so on.
Don't take any of these as recommendations! I'm just throwing out examples off the top of my head. And most (but not all) of the examples above are extremes on one dimension or another. Most of my actual favourite strings are reasonably well balanced - not super bright or super soft or super anything, just a really nice combination.
Elixirs are quite stiff. Don't put Elixir 12s on, they will feel a gauge or even two gauges heavier than the Newtones. Elixir 11s? Maybe, maybe not. I hesitate to recommend any sort of 10s for an acoustic, but that's just me. BTW, I like all of the strings @Mellish mentions except the EJ11s which I haven't tried yet. But whether they are right for what you are trying to do is another question.
I gather that you like low tension and you enjoyed the Newtone Heritage set. If they are anything like the other Newtones I have tried, they will be very treble-heavy and a delight under the left hand. What makes you want to move on from the same again?
Oh, a while ago someone here (Artibear?) mentioned that Lowden strings are repackaged Cleartones. I thought my set of Cleartones was OK, nothing special, and hard work for the left hand.
@Soupman ; - drop me a PM if you need a tech recommendation.
Cheers both
@TheMadmick I think Lowdon 12s would be a strain on the bridge if they're anything like the Elixers that Lowden used to recommend.
Used Martin's in the past but don't remember which ones - 'bright & jangly' isn't what I'm after. Thanks though.
@Mellish - tried Sunbeams before & seem to remember they were good. However, I found an unopened pack of EJ26s (p bronze 11s) so may stick 'em on.
@Tannin - wow, yes I think I need to decide what sound I'm looking for. I will study your advice/suggestions with a view to sorting out my requirements.
As to sound, I mostly use a thumbpick so reckon I'm looking for even string volume and a bit more volume, whilst trying to lower the string tension for the bridge. I'm not worried about ease of fretting so much.
Detail of soundboard/ bridge showing the repair. I seem to remember the chap said he'd re-glued it as well as putting the 2 screws through.
I could take it to a Luthier but what do I ask him to do?
From what I gather it's not worth a lot, it was always a mid-range instrument at best, although I do love it.
Big thanks to all for the replies, most helpful !
I knew there weren't many made. I read here people saying 'try several before you buy' but when I bought it there weren't any others if I remember correctly (it was 30-odd years ago).
My choice came down to the Flambeau or a Washburn in another shop half a mile down the road. I went between the two a few times .
a) have ball ends and
b) do they work with a soundhole magnetic pickup ?
(I occasionally take it to open mic nights or plug it into a DAW).
Thanks!
These are Pyramid 307 Silver-Plated. I bought them from Strings by Mail for $18.83 AUD (£10.50) including postage from the USA. (UK prices are usually way dearer than the US or even Australia, partly because of your worst-of-breed VAT which at 20% is a fair-dinkum shocker. But for once, Strings Direct in the UK list them for £8, only they seem to be are out of stock.of 12s, which would be the gauge to have.) And I see that Thomann have them in stock at £4.22 including VAT, which is a screaming bargain.
The 307s are really interesting strings! They are very soft and flexible under the fingers, an invitation to fast and fancy fretting. The silver coating is not rough or raspy but it micro-grips the fingertips as if it was coated in rosin or non-slip rubber (that sounds unpleasant but isn't). They are very light for 12s, more like 10s but perfectly playable nevertheless. (This is why I say get the 12s. 11s would be crazy light.)
Their sound belongs to the same broad family as a standard set of, for example, phosphor bronze strings, but without the stridency. It has a gentle, very slightly muted flavour not unlike (but much more subtle than) a silk and steel sound. They excel at fingerstyle but strum happily too. (Contrast with silk and steel which tend to flub a bit of you strum them.)
I put them on my Mineur (luthier-built concert size guitar) and it loves them. I think they would also go very well on any melodic, sweet-voiced guitar. For @Soupman they might be the very thing.
Pyramid 307s seem like rocking horse crap here in UK.
The best was Thomann but the postage was £8, however a multiple order also seems to ship for same, so not bad.
I haven't tried the silk & steel but will keep them in mind for the future.
I said I was pleased with the Newtone Heritage 12s, and have just placed an order for a set of Heritage 11s as they have a little less tension.
This guitar mainly gets played at home, so not a need for volume.
But for me, I just find the Strings by Mail and Strings and Beyond websites more complicated, maybe cos I'm not used to them
But sure, I see the fast delivery angle. Strings Direct are way more expensive than anywhere in the USA or Germany - largely no doubt because of the insane VAT rate in the UK. I was wondering if perhaps you have to pay 20% VAT on a set of strings from the USA, or something like that.
Thomann have their prices in £ and include the vat. I've never used them but as you mention, one shipping fee for a few sets seems good value.
(They charge me Aussie GST, but 10% is bearable. And in any case there is a way around it, which I won't mention here in this family environment.)
But it was still priced in dollars I think, hence the conversion bank fees.
