Introducing Smorg ***update***
  • They look really nice @dindude
    Best of luck with this!
  • KebabkidKebabkid Frets: 3324
    Great work D and they look pro! All the best with those
  • dindudedindude Frets: 8540
    edited August 2014
    Both Guinea Pig boards are out there in the real world now, here's the large one courtesy of @GIJoe ;
    Thanks to GIJoe and @Digitalscream for their Guinea Pig duties, both a pleasure to deal with and some great feedback coming through which is pleasing:)
  • Just for completeness, here's its smaller brother:
    <space for hire>
    I'd have one of them if you could get it a bit thinner and more angled like a Pedaltrain is. I have a Diago Showman and it's a flat profile, and it's a bit annoying to reach some of the rear pedals because of it.
    They're only about 15mm thick at the sides :)
    However, I've been thinking the same thing - maybe have an option for the rear feet to be raised (and angled a bit)? Shouldn't be hard to do with an C-shaped bit of aluminium...
    <space for hire>
    As has been said, they are quite thin. I'm not a fan of angled boards personally, just because they only place the footswitch of a second tier pedal just above the knobs of a first tier pedal, so still not a great solution for me.
    My solution will be to offer risers, here's a prototype of a 300mm length "low-riser" which sits about an inch of the board. There will also be some "high-risers" that will give about 45mm clearance that will be suitable for power supplies to fit underneath.
    http://i1137.photobucket.com/albums/n505/dindude/ab694f3574f858498fd5a5078dca9f06_zpsfd82b531.jpg
    What the thoughts on this?
    Cheers
    And here it is on a populated small board. Will leave enough room or either a power supply or a wah.
    http://i1137.photobucket.com/albums/n505/dindude/35d23300ebbf3ba067d22e72835a9874_zps6300ff0e.jpg
  • Yes, and can I have one please? :)
    The slightly annoying part is that I only need about 30mm clearance...by the looks of it, that one up there ^^ is going to be a couple of mm too low :(
    <space for hire>
    The main thing for me is to be able to have the pedals at the front as low to the floor as possible, so I can rest my heel on the floor and tap tempos and make changes without hovering my foot in the air. Even with my Diago this can be a bit of a problem.
    Yeah, totally get that, these are pretty low profile, including rubber feet, it presents the pedal platform at 35mm above the floor.
    You probably won't find a pedalboard thinner than this, so attack the problem at the heel end of the foot instead of the toe end. Why not just put a bit of MDF in front of your pedalboard to raise the "floor" a bit?
    <space for hire>
    I'm sure it's fine, I'm just being anal. Probably wont move from my Diago unless it's to something much better. Also I tend to screw my pedals down (some of them!) and so would hate to ruin one of your nice boards!! :D
    Believe it or not, I actually had not thought of this. Hmmm... interesting.
    Sounds like I need a middle-riser!
    I'll PM you this evening when home from work.
    edited October 2014
    So the Guinea Pig boards have been out in the wild for a couple of months and feedback has been very good. The only thing I'm looking at changing is the handle to make it more user friendly when using a riser.
    @digitalscream has been particularly great for bouncing ideas around.
    I have come to the conclusion that this project is going to be a slow burner though, I'm stupid busy at work right now so time to make boards is rare at the moment, and I need to sort my workshop (aka big shed) space, I'm a little too reliant on the Garden at the moment for the winter months!
    Finding a decent hardcase at a half decent cost has been troublesome so I'm going with a soft case solution, a padded satchel bag (with an internal pocket) like this: excuse the crappy iPad pics.
    I have a snazzy website that is around 70% complete, but to be honest, until I can give the time to it I won't be launching, I will just make a few boards and risers when I can and sell on to those interested. So if anyone on here is interested and has a little patience then PM me.
    And finaly for a bit of fun, from the unofficial Smorg Custom Shop, I did manage to finally get near to completing this one today, bar a bit of final finishing.
    One to leave a bit of space around the pedals for once I reackon.
    Cheers
  • As there's no room for a ps under these, could a bracket be fabbed for attaching to the rear profile? Cioks make some long / flat supplies that could work in that location.
    Just use the shelf/riser instead:
    <space for hire>
    ^^^^^ yeah, the risers I make alongside the boards have enough clearance for all the well known power supplies.
  • JayGeeJayGee Frets: 1267
    This might be a Bloody Silly Question, but...
    Does the board still fit in the case/bag with a populated riser in place?
    Yup, the bag is purpose made and has enough room for the riser with pedals on top.
