New to Bass - what should I get?
olafgartenolafgarten Frets: 1648
Hi all, recently I've wanted to try out playing the bass. I know very little about bass guitars and had a few questions about what I should buy and how I can use it.
Firstly, I'm considering whether I should start with a short scale, I'm not very tall (around 172cm) so would a shorter scale work better?
Next would be whether I can use it with my Katana. I have a Katana 100 but would only be using this at home where I keep it on 0.5 watt mode most of the time, would this sound any good and is it possible to do any damage at that volume level?
I don't want to spend very much as I'm just trying it out to see if I like it, so probably aiming to spend under £200 on the guitar.
Any advice or recommendations are much appreciated.
«13
  • Can’t advise on what to buy, but a common criticism of guitarists* when they switch to bass is that they “play bass like a guitarist”, so my advice would be to really strip it back to the basics and listen carefully to bassists, so you play like a bassist, not a guitarist.
    *including me. I’m a rubbish bassist.
  • stickyfiddlestickyfiddle Frets: 27233
    Oh god that - playing bass well is about playing sympathetic basslines that are complimentary to the rest of the arrangement. Most guitarists when they pick up a bass think it's just about playing roots and 5ths, which is fine but utterly boring for player and listener alike (in most contexts).
    In terms of kit you can't go wrong with a P-bass unless you already know it's not right for you (e.g. you have your heart set on a Hofner, or all your bass heroes play Jazzes, etc). Don't worry too much about size & scale. I'm 180cm and don't have especially beefy hands and I get on just fine with a 34" Precision. Short scales are great but they sound different and don't help guitarists feel more like it's a different instrument and hence play it like a different instrument.
    Thanks, I'm pretty bad on guitar as well, so don't expect to be too great on bass.
    But I do know it's not meant to be played like a guitar, I've always appreciated a great bass line, it's the sort of thing you don't notice outright but elevates a good song to a great one.
    I'll start looking into some P Basses, I was probably looking into a Fender style anyway.
  • ICBMICBM Frets: 72646
    I find the bigger problem with traditional P-Basses is the neck size, not the scale length - if so you may find a Jazz more suitable, although many modern Ps have less-huge necks too. (I've just picked up an old Washburn, which is essentially a reshaped P-Bass, and has a skinny neck.) Mustang Basses are also nice - I prefer the ones with the traditional mini-pickup - and sound good regardless of scale length. Don't rule out the cheap Squier Bronco either - they can be genuinely good despite the very basic pickup and bridge.
    You can use the Katana at home, although you will probably want to set it to a higher power than 0.5W even if you're not playing louder - they just sound less crap ;) better like that. The only risk is to the speaker, so if you're not at the level where that's starting to have to work too hard or distort then it's fine.
  • slugeliseslugelise Frets: 112
    I'm slightly biased because i've just bought one but you cant go wrong with a squier Classic Vibe Jazz bass, got mine for £190 so keep an eye out for a used deal. Vid here comparing it to a £4k CS bass, its hard to tell the difference playing it.
  • SteveRobinsonSteveRobinson Frets: 7079
    edited October 2022 tFB Trader
    Indeed! When I bought my CV Jazz Bass I tried them all up to the American Deluxe, which just pipped it on sound. As in the video above the expensive one had more depth/body to the sound but there wasn't much in it and I thought that was probably down to pickups which I could always change. Playability-wise there was nothing in it so I saved £1K.
    I echo what @ICBM says about P-Bass necks being big. I can't get on with them hence the Jazz Bass.
  • thermionicthermionic Frets: 9671
    I’m 167cm and have no problem with 34” scale, although I wouldn’t be surprised if a shorter scale bass would be easier to play (in much the same that my GS Mini is easier to play than a dread). Always gone for a Jazz but apart from picking up a friend’s 70s one many years ago I haven’t played a Precision in anger. Big fan of Squier basses (another Classic Vibe owner).
    Regarding amps, you can pick up nice amps from Fender, Ampeg or Orange for a little over £100. Not loud enough for gigging but a big improvement on playing through a guitar amp around the house.
  • OssyrocksOssyrocks Frets: 1673
    I did exactly what you are doing late last year. I picked up a cheap Squire P bass for £100 off ebay to see how I got on.
    Roll on 10 months and I've got a vintage 70's P bass and a big Markbass rig and I'm playing in a band!
    I steered away from any bass I might have considered "easier to play" with a shorter scale length and decided to bite the bullet with a 34" scale bass right from the off. I'm glad I did, as I feel very comfortable on it now.
    I would say pick up a cheap P bass and see how it goes. Be aware though, the guy I got the Squire off had wanted to learn bass and said he just couldn't do it, and when I saw the bass he sold me I knew why, I could fit my fingers between the strings and the fretboard! It took some setting up, but I got it playing nice in the end. When you're new to bass, a good setup and action is very important, well it was to me anyway.
    Good luck!
  • FunkfingersFunkfingers Frets: 14573
    The first thing that you need that can not be bought is bigger calluses.
    On guitar, calluses develop near the fingertip, covering roughly the last third of the last bone of each finger.
    On bass guitar, the strings meet the fingers roughly half way along the last bone of each finger.
    The second thing you need is a change of mindset. Bass is more than just a bigger electric guitar with fewer strings. It fulfils a different function within a band context. Bass is what dancers wiggle their butts in time with - even when the player is Les Claypool!
    The third thing you need is attitude.
  • KKJaleKKJale Frets: 982
    I feel moved to gently suggest that that doesn't sound quite optimal.
  • prowlaprowla Frets: 4949
    Buy a used Fender; if things don't work out bass-wise you'll be able to sell it for what you paid so it'll be a zero-cost adventure.
    I'd not bother with short scale ones, tbh; the idea that your bass has to be as near to the guitar doesn't really hold water IMHO.
    Best idea is to go find a music shop and play a few, p and j fender (as someone else said, you'll get your money back), and the delights of 4/5/6 strings (hint you only need 4)
    You don't have to buy new from a music shop, but just get a feel there, then find something 2nd hand when you know that you want.
  • dindudedindude Frets: 8540
    Whatever works for you, I have a short scale and really like it, and I really am trying to develop bass player technique and mindset. I find personally going to a P Bass which feels massive and I revert to plectrum and root note trappings as I’m not comfortable.
    Either way the Ibanez Talman are crazy good basses for around the £200 mark they do both a 34” and 30”.
    This is the whole point to me - you're not immediately comfortable so you're less encouraged to play it like a guitar. It's a good months-long process to get there and after 2 years I'm nowhere near where I'd really like to get to but that intro process where you have no choice but to play it differently is super-important imo.
  • chrisj1602chrisj1602 Frets: 3999
    You can’t go wrong with Squier Jazz or Precision. Even if you are planning to buy used, I’d recommend going to a shop and playing a couple first.
  • p90foolp90fool Frets: 31663
    I'm tall, but a hand injury means I struggle with a full scale P-Bass these days, so I bought one of these;
    https://www.guitarguitar.co.uk/product/181218336171008--ibanez-tmb30-short-scale-bass-mint-green
    I absolutely love it, and it sounds great, with no dead spots.
  • bertiebertie Frets: 13570
    therapy
  • RockerRocker Frets: 4993
    That type of behaviour is just plain wrong IMHO. By all means try a bass or two in a shop but if you like what is in your hands, buy it from the shop. Otherwise take a chance and buy unseen from an internet seller, which might cost less but there is more to value than price
    Nil Satis Nisi Optimum
  • KebabkidKebabkid Frets: 3336
    edited October 2022
    As you appear to be in Surrey, I'd get down to Andertons and try what they have but you can't go wrong with a Sire and they have a great selection of them and I believe the only place you can find them in the UK
  • Dave_McDave_Mc Frets: 2369
    Yeah, I don't much like doing that either. It's not completely black and white- I don't think there's a problem with trying something that you're just curious about, to see what it's like. If you really love it you may buy it, for example, or it may sow the seed of GAS and you may get it later. But actually trying something where you know going in you're going to buy elsewhere- it's obviously not the crime of the century or anything like that (and to be clear, I'm not suggesting for a second it is), but it doesn't quite feel like cricket either. Not illegal (nor should it be), but not quite 100% totally ethical either.
    Of course, you could tell the shop (only really applies if buying new) about the cheaper price elsewhere and give them a chance to match it (or get close). That's probably (just about, and only if you suspect they can get close) ok. The other problem is that you might like the one you try in the shop more than the one you buy later online!
