Manufacturer warranty Vs local luthier
thomasross20thomasross20 Frets: 4437
edited October 2022 in Acoustics
So I've decided I want to refine my Avalon further to make the playability 100% perfect (for me as I'm a fussy bugger!). I got the saddle shaved recently by a local tech but it's not quite there. Avalon say although this voids warranty, they will still take it in for a free check (other than parts, if needed) for £70 return to Ireland. Very good of them.
Prior to them telling me this I'd booked a luthier in Perth, an hour from me. Think will cost more but seems very good, it's a bespoke service where I sit with him for 2 hours while he does some work on it, I try it in person and he explains the process (the main advantage here is immediate feedback as I'm picky about action). There's no going back to Avalon after this I would think. No shipping "hazard" with this option.
Thoughts?
  • MellishMellish Frets: 947
    edited October 2022
     I'd say do your homework.
    There's good techs and those who are not so good. But at least if you're there, whatching, that's a good thing.
  • BillDLBillDL Frets: 7408
    edited October 2022
    Probably a bit late, but personally I would have asked the luthier that reduced the saddle height to have ordered a matching spare saddle, adapted that to thickness and width, and had that filed or sanded to a suitable height.  That way if something else later happened to the guitar that required sending it back to the builder you could simply have reinstated the original saddle and they would have been none the wiser.
    As far as I am concerned filing a bit off your own saddle yourself is part of an acoustic guitar setup to personalise the guitar without having to be a professional luthier and should have no bearing on warranty.  Would THAT have invalidated the warranty or is it simply the case that the builder doesn't like independent luthiers touching the guitar for what is a very simple job? You aren't going to damage anything else by lowering the saddle, so I really don't know what the big deal is.  I realise that some warranty clauses are strange, like the very restrictive conditions that Ferrari tie customers to when they buy one of their cars.
  • Agree about lowering saddle not being a big thing tbh. So yeah both options are good - might be leaning toward in-person set-up next week but will see
  • octatonicoctatonic Frets: 33848
    Lowering a saddle voids the warranty?
    Get to fuck.
    I would absolutely chase that up with Avalon and get in writing that lowering the saddle does not void the warranty.
    Saddles and nuts are consumable products like strings.
    They wear out over time and should be replaced.
    Are you taking it to a luthier, or a repairer?
    Luthier is a contentious term- it implies advanced skill than many repairers simply do not have, despite using the term.
  • Luthier - I previously took it to a tech. The saddle had been lowered to help with action but the string break angle is now a bit shallow. New guy is an hour's drive away (David Antony Reid) - seems to get a good name and is a luthier.
  • ...., it's a bespoke service where I sit with him for 2 hours while he does some work on it, I try it in person and he explains the process (the main advantage here is immediate feedback as I'm picky about action).
    Reminded me of this sign a mechanic I used years ago used to have up in his shop:
    What is the life of the warranty?
    If, like Martin/Gibson, it's very limited, then going to a competent Luthier and voiding the warranty isn't a big deal.
    On the other hand, if it's for the lifetime of the guitar like, say, Atkin (I believe).....
  • FelineGuitarsFelineGuitars Frets: 11640
    It was Avalon when they were bearing the Lowden name 25 years ago that said to me that guitars needed to go back to them for truss rod adjustments - the truss rod adjuster was/is positioned behind a lateral brace that makes getting any key in there all but impossible. I thought that was a bit daft as things could easily shift in transit and change of environment.
    I would see that a saddle height adjustment should have no bearing on warranty
    However the idea of a replica saddle cut to optimal height is a great idea to make it so the guitar could be returned to factory conditions should it need to be .
    I have often felt that owning a second saddle of a slightly different height  might be useful to players whose guitars are affected by changes in seasons - in fact when Martin had a non adjustable truss rod it was almost a "must-have"
  • I can't see how lowering the action by sanding the saddle should affect a warranty, it's simply maintenance surely?
  • Ah just to note the tech did also previously adjust their truss rod one quarter turn - it may have been that which voided it. Not trying to create a hoo-ha :) And yes, access to the Avalon truss rod is very tricky. Replica saddle is indeed a very good idea and noted for future. Can't recall how long the warranty is for.
  • droflufdrofluf Frets: 3770
    If you're comfortable with the warranty situation I'd take it to the luthier; apart from removing the risk of damage in transit probably, given that we don't know how you drive :) , if it's not perfect first time you can get it fine tuned.
  • Yep - next Friday I'm booked in to get both my acoustics a quick check. If anything "big" (99.999% doubtful) needs done, can use Avalon else will get the guy to tweak it while there.
  • MSedgMSedg Frets: 123
    Shaving the saddle down voids the warranty? New one on me. Combined with inability to adjust the truss rod I guess Avalon’s off the list, they don’t sound particularly player-friendly. A shame because I’d always fancied trying a D300, but inability to adjust to player preferences/weather/different string gauges without voiding a warranty rules it out. A bit short-sighted on their part to be so prescriptive, in my view…
    Again, that seems bizarre. All very well if you are local, but this company is selling internationally! If this is indeed their policy, I'm sure they don't advertise it.
  • Interestingly, my first Avalon had the Velcro for the pick up battery holder over the truss rod adjustment. When I asked, I was told that they had several butchered. They then sent replacement Velcro and 2 (short) 5mm Allen keys.  However, when I asked them to move the battery Velcro when it was back for adjustment, it came back with the battery Velcro moved (exactly where I haven't checked but it's not over the truss rod adjustment).
    Might be worth a phone call to Steve McIwrath to get the matter cleared up. I think any claim that was not attributable to the saddle adjustment would stand and you could take them to the small claims court if they didn't play ball. I've found simply the threat of the small claims court often does the trick.
    I stress, you need to get clarity before any small claims go ahead. E mail should be sufficient. If they don't e mail you, e mail them with the agreement and let them contradict it.
    Good luck. Lovely guitars though!
  • Honestly guys, it's all good.. they're good to deal with and the guitars are great. Don't let this put you off an Avalon. Anyway I'm going to take to local luthier and hopefully get the action just as I want it.
  • SoupmanSoupman Frets: 239
    Adjusting the truss rod invalidates the warranty??!!
    So every time you change string guage/tension you are supposed to send it back to them to tweak the truss rod?
    There's lots of great guitars out there - stuff 'em.
  • ToneControlToneControl Frets: 11991
    I'd assume that lowering the saddle would just mean that Avalon wouldn't want to get involved in remediating the saddle if it had been done incorrectly, i.e. "voids the warranty for the saddle itself"
    Avalon have never said anything to me about truss rod adjustments being forbidden, they've been happy to tell me what size key to use when I've asked
    Also: you can use a rosewood or ebony shim underneath the saddle if you want to raise the action, not essential to get a new saddle
  • That's a good point - Larrivee put a shim under theirs usually - I removed it and it was then the perfect height for me.
  • maltingsaudiomaltingsaudio Frets: 3145
    edited October 2022
    Was going to suggest you take it to Jimmy Moon in Glasgow but he’s moved to Arran! But from the website Don't forget - Stephen Devine - our long time employee has carried on at the Glasgow address and his focus is on structural repairs and refinishing.  He has the same phone number as before (0141 632 9526) and his email is Devineguitarrepair@gmail.com
    www.maltingsaudio.co.uk
