Only had a quick go with it, but it's pretty nuts.
This is what it sounds like:
Intention seems to be a huge sounding Gilmour emulating pedal.
Appears to be a fuzz stacked into a distortion meaning you get loads of sustain, but it's not too fizzy and shrill into a clean amp.
I'm loving it so far, very impressed that it also seems to work really well when you pull back the distortion especially on the "Tight" mode where it becomes a nice beefy distortion as you roll it back.
My only concerns are that perhaps it might be voiced a bit too dark. Nearly all of the demos I've seen have the brightness on nearly full. It's fine for me as I have a fairly bright amp, but I can imagine it causing some people issues.
The problem I've had with Wamplers in the past is that they can be bedroom pedals in my experience. Amazing at home, OK at practice and lost at the gig so that will remain to be seen.
I'm interested to hear others experience who have invested in one and especially any comparisions with the Suhr Rufus.
I'll update with more info as I get more chance to play it.
My music:- https://soundcloud.com/hubobulous
@monquixote congrats on the NPD. I'd be interested how you find it in the cleaning up dept, and if your Tenny has Filtertrons what you make of it with those. Sounds good though, seems like it has enough balls to be heard in the mix too.
