This was apparently listed on a US retail website before getting pulled down. $499 retail.
Looks like they might be targeting an audience after a "mini kemper stage" type of pedal?
Manufacturer's blurb:
TONEX Pedal lets you store and play thousands of the world's most sought-after amps, cabs and pedals - or your own gear, modeled in minutes.
IK's ground-breaking AI Machine Modeling technology captures every nuance of any guitar and bass amp, cab or pedal. Choose from an online library of thousands of rre, one-of-a-kind rigs, or use the included TONEX software to literally model your own gear at home on your computer.
TONEX Pedal includes 480 Premium Tone Models of your choice plus unlimited access to free user Tone Models, for a limitless supply of sonic inspiration. In addition to letting you load up to 300 separate Tone Models to use at once, TONEX Pedal also offers IK's award-winning VIR(TM) cabinet and mic simulation, a custom IR loader to use your own impulses, plus an advanced noise gate, analog-modeled EQ and compressor, and stereo reverb derived from our award-winning AmpliTube X-TIME pedal.
Made in Italy, TONEX Pedal features a rugged aluminum chassis, 24-bit, 192 kHz processing, massively wide 5 Hz-24 kHz response, and a whisper-quiet 123 dB noise floor. Plus TONEX Pedal also doubles as a 24 bit/96 kHz USB audio interface, so you don't need any other gear in the studio. And a convenient Editor application makes it easy to explore Tone Models and sync back to TONEX Pedal for never-ending inspiration.
Feedback thread: https://www.thefretboard.co.uk/discussion/comment/3575378
https://www.instagram.com/insta.guitarstuff/
I remember the hype when their first pedals (reverb/delay/mod) in this format were launched but it looks like shops can't give them things away now.
It is possible they have better captures available now.
pedals (e.g. overdrive) --> tonex (including cab sim) --> time/mod pedals --> amplification (pa/frfr/headphones)
or as someone just said, put it in the loop of a multifx box and route it at will.
A loop is to put time/mod effects after preamp but before power amplification. There isn't any power amplification in this afaik.
Also why the blackstar amped 1 needs a loop.
Sounds pretty good to me.
