So I have been enjoying my new Yamaha 4 string bass but noticed something off today which I managed to trace to the bass side of the spilt 'P' pickup. I was noticing some serious buzzing and first thought I was a bit too close to the computer monitors in my den (as the PUPs are single coil). However it only happens when my thumb touches the pole piece under the low E string. When I realised this I touched the other poles on that split - same thing. Nothing on the other split (the ones under the D and G strings) and nothing on the bridge pickup. Makes me think this is a faulty pickup and not just a ground wire issue. I will, of course, be phoning the Yamaha store on Monday but any thoughts or suggestions from any techs on her would be most welcome. Thank you in advance.
You could get around it by reversing the hot and ground connections on both pickups (so they remain in phase) which will make the polepiece grounded instead of hot, but if the bass is new that’s not really your problem.
The problem is that if you send it back and it’s not doing it at the time they test it, they’ll think it isn’t faulty. Best to take a video showing the problem, if you can get it to do it again!
