What's a good seven string
You know, to play heavy like, after I've had a few lagers.
I like narrow nuts 39mm ish and neck pockets.  Jackson?  Big no?
Backdoor Children Of The Sock
  • LewLew Frets: 1657
    edited September 2014
    39mm? Good luck with that! :O My 7 is 50mm. Ibby are 48mm. I like the 1527 cheap and decent enough. :-)
  • Ibanez RG1527 and RG7620 spring to mind. I've had the 7620, probably the best 7 string I owned.
  • Sambostar said:
    What's a good seven string?
    A broken seven string?
  • SambostarSambostar Frets: 8745
    Obviously it won't be a 39mm nut, but on my Knamer thing it's a narrow nut and a 2 3/16" neck pocket.  I don't fancy the classical stance and justn want to noodle heavily with another string as I don't like drop tunings much.
    What is the nut on the Ibanez compared to a Jackson?  Thinking the Jackson might have a fatter neck?  Fatter is good.
    Haven't considered other brands to be honest.
  • Schecter's have fairly fat necks.
  • Looked at the atx C7 but it's a straight 16".  Don't think I could handle that low down. Leaning towards Jackson Radius.
  • Hertz32Hertz32 Frets: 2248
    Get a six string and put baritone strings on it? Tune it like a seven minus the top string unless you are really intent on high up noodling
    EDIT: thats what I'm probably doing to my Dean Soltero. Earnie Ball make a 13-72 baritone set that I want my nut re-cut for as I drop tune to A and 12's arent cutting it. Standard gibson scale length on my dean too I think.
    'Awibble'
  • Maybe try and find a Jackson COW7. Has a thicker neck than a Ibanez. There's a couple for sale on Gumtree right now.
  • impmannimpmann Frets: 12674
    One with 6 strings on it and an angled Telecaster bridge pickup fitted at the neck position.
    If you are set on a 7, you'd be foolish not to look at a Chapman ml-7. BRILLIANT guitar for the money. £500 gets you ebony fretboard, satin neck and hipshot hardware! I really fancy a tele shaped one. Not sure about neck thickness but it's probably bareable :) go to Andertons in Guildford and play one if you can.
    'Awibble'
  • JetfireJetfire Frets: 1696
    If you want heavy but standard 6 strings, you could do worse than a baritone. Also, I just happen to have one for sale lol
  • frankusfrankus Frets: 4719
    does it djent?
    @Jetfire dont even go there man, I am GASsing for that thing so hard and i cry when I remember my GAS fund is less than £100 right now.
    I am in love with that damn guitar. :D
    'Awibble'
    Haha its beast! I take trades and kidneys too...
  • I've played a few 7s, and while I know they're not for me...if I was going to get one, it'd be one of Jaden's lower-end creations (Series 2-7, a shade under a grand I believe). I've played a couple of Ibbys, a Schecter and a few Jadens. Of all of them, Jaden's Original Series 7-string was the least offensive to my hands ;)
    <space for hire>
  • OctahedronOctahedron Frets: 400
    Hmmm I hear Ibanez and Schecter make some good 7-strings.
    Then, when you're finished with it and decide it's not for you, let mdphillips make a clear tone greasy sausage fingers conversion/creation/part-Tele out of it for you (or a friend). :)
    Music the great communicator, use two sticks to make it in the nature - a music reviews blog: http://usetwosticks.wordpress.com/
