Which A/B Box?
lincolnbluelincolnblue Frets: 294
I'm thinking about buying myself an AB box.
I mainly play guitar at church and usually play either electric or acoustic. However, there are times when I need to use both. I use the same pedalboard for both.
So my plan is to have one output going to the amp (electric) and one to the DI box and the PA for acoustic. I can put my tuner on and silently switch guitars easily.
I don't want to spend much on one as I'll not use it too often. Can you recommend a good one? Anything I should look for or avoid?
I guess I could also have one at the beginning to put both guitars into rather than swapping. Then I could press the footswitch on both pedals to change guitars?
  • I use the Switchblade and it just does what it does with no hassle. No LEDs etc, but a great pedal.
    The guys that do The Nose expression pedal also does different ones I think
  • paulnb57paulnb57 Frets: 3065
    edited September 2014
    I have a Bright Onion one that is surplus to requirements, same as this, sends the signal to A or B and mutes for tuner......£35 mailed, only issue is the sticker came off so the legend is engraved onto the top, can send you a photo of interested.......
  • Paul_CPaul_C Frets: 7839
    +1 for the EHX Switchblade
  • ICBMICBM Frets: 72579
    Whichever one you get, make sure it's a type which grounds the unused output instead of leaving it open circuit, or it will produce hum on that channel.
  • Lehle is all you need others may give ground loop problems
  • GassageGassage Frets: 30945
    The ground hum is a big issue. The other issue is Phasing if using 2 amps together.
    +1 on Lehle. The Radial ABY is also brilliant and cheaper.
  • John_AJohn_A Frets: 3775
    Got one of these too, they are transformer isolated, so hum free and it's been totally reliable. For £35 it's a much better option than a switchblade or similar
  • Little lehle. Pricey but worth it.
    Pretty much the same as the bright onion, but £100 more expensive for a pretty red box :)
    >:P If you can post a picture that'd be great.
    How can I tell without trying whether on will ground the unused output? Do I want passive or active?
    Apologies for the angry face thing...was writing on my tablet and didn't realise I'd pressed the "face" button!
    Heres a photo of the Bright Onion, I bought it recently from this forum to test if an issue I had was with my other looper pedal, it wasn't so this one is surplus, the engraving I did is a bit hammy but the pedal works as it should, 9v (same as Boss) supply gives LED indication of status but it works just as well without….
    2 loops and muted tuner output
    Happy to trade for Analog delay or clean boost…..
    Paul
    That one is different to mine so I cant say 100% if it's transformer isolated so I would check
  • ElxElx Frets: 412
    Carl Martin Route box...
    I've got one, so it's a must have :)
    This is the one I've got :
    http://www.brightonion.co.uk/active-aby-pedal-with-isolated-second-output/
    Good value at the new price if you can't find a used one, I'd be wary of the Analogman one without knowing whats in the box, a simple ABY is three jack sockets and two switches and can lead to all sorts of hum issues
    EDIT - Just saw you are looking for an AB not a ABY - if you are only running one amp at a time just about anything will do :)
    LOL- I'd take anything Mike made over the Bright Onion stuff. I had one item from them and literally threw it away it was that bad.
    Ask the chap at Bright Onion if you're getting one of those. You just want passive, no need for an active one if it's on the output of a pedalboard.
    You also don't need to worry about ground loops if one side is going to a DI box, since they always have a ground lift switch.
    Really?
    The chap in the Red Hot Chilli Peppers uses an enormous Bright Onion looper box for his pedals, switches them in and out individually. Always assumed they were good.
    What was wrong with yours?
