Sale, Guitar Kits
GSPBASSESGSPBASSES Frets: 2354
edited May 2023 in Parts £ tFB Trader
Smugglers TC Black guard, Swamp Ash body, cavities under the pick guard as per standard smugglers version of the TC. Neck is made from Birdseye Maple with a Rosewood fingerboard. Frets JD 6105, thickness at the 1st and 12th fret 22.4mm, 24.4mm, head stock drilled for vintage style tuners. weight with neck 5lb 7oz.
£270 + £12 P&P.  SOLD
There is a Wilkinson hardware kit available for this TC, the kit includes all hardware you need to build the guitar. £50.  The kit can be upgraded with Oil City pickups plus £70.
LPJ single cut, made from all Mahogany, the neck is a three-piece laminated, it has a rosewood fingerboard, frets JD 6100, thickness at the 1st and 12th fret 21.6mm, 23.5mm. head stock drilled for vintage style tuners. weight with neck 4lb 12oz, the body is lightly chambered. This is a B sock guitar, only because there’s a colour difference in the woods that make up the neck see photo below. There is some slight damage round the post holes, this was my fault when I pushed in the post's in too hard, this will not show when the post's and bridge are fitted.
£250 + £12 P&P Sold
There is a hardware kit available for this guitar, which includes everything you need to build the guitar. This kit contains a dog eared P90 hand wound custom pickup from Hot Rod pickups. £110
Sold
LPJ DC made from Brazilian Mahogany, the neck is a three-piece laminated, it has a Rosewood fingerboard, frets JD 6100, thickness at the 1st and 12th fret 22mm, 24.2mm, head stock drilled for vintage style tuners. weight with neck 5lb 6oz.
£400 P&P free Sold
Sold
