Can anyone make a Novo Miris-inspired body?
I really like those things but can't justify buying a Novo right now. Anyone can make a body for a partscaster? Doesn't need to be an exact copy, fancy or even finished
https://www.novoguitars.com/miris
  • Is this too big of a pain to do without a template?
  • earwighoneyearwighoney Frets: 3503
    It's not a Miris, but influenced by another Novo.
    If you have a look at the original YT link, there is a PDF template provided.  Maybe someone like Guitar Build could create a custom body for you from the template?
  • Jez6345789Jez6345789 Frets: 1802
    Even if you have not done it before making a template and a body can be done over a weekend with basic hand power tools if the shape is what you need in the plan print off the plan pdf stick it on a bit of 10 mm mdf and you are off to the races. If you want semi hollow which I think the Miris is then get a body blank thicknesses to say 7 mm less then you can easily rout out some voids add a drop top and then glue on the top and finish routing with the template. I am not back in the Uk till July but have a serious cnc in the warehouse and it would take a few hours to get that thing setup and it will churn them out by the dozen lol.
    sure there is someone who can help before then or just get a cheap blank and have a go with power tools or if you can wait till  I’ll after the 15th July I have a week back at the warehouse so could get one done it it helps.
  • WezV said:
    I spoke to @GSPBASSES about RB6 and very-very tempted but would be really keen to get a Miris!
  • WezVWezV Frets: 16875
    Is the problem not having plans available, like there are for the RB6?
    Anyone who has ever made a guitar should be able to do this for you, just expect some to not want to, and to pay more for the design work involved.  It can be just as much work copying an existing design as making one up from scratch.
    Some have the mentality that the builder gets to re-use the design/templates, so shouldn't charge the customer for the work involved in producing them.   This is rarely a good deal for the builder.
    It's not too difficult to make accurate plans from a full pic and some known dimensions.  I used to do this by printing off very large pictures and attaching to some template material, similar to the way @gspbasses shows in the thread i linked to.
    More recently I have been doing them in inkscape and cutting out with a laser.
    Something I did notice about the Miris that you don’t get till you dig in a bit it does have an arm contour so is not as deep body on the upper side. Not the end of the world but it’s more subtle than a strat style. So it’s not just a slab with a top like a thinline tele.just for reference
  • Something I did notice about the Miris that you don’t get till you dig in a bit it does have an arm contour so is not as deep body on the upper side. Not the end of the world but it’s more subtle than a strat style. So it’s not just a slab with a top like a thinline tele.just for reference
    Presumably it makes it a bit more difficult to make as you're gluing the top at an angle? I also _really_ like the s-hole design
  • RolandRoland Frets: 8816
    Hmm. Offset hollow body with forearm contour and top binding. That’s not a simple build. If you went semi-hollow, with a cavity below the F hole then it would be easier. I guess it’s a case of deciding which features are important.
    Fine without binding, in fact probably prefer without it. I thought it is semi-hollow like a thinline vs hollowbody? Maybe I'm novice and wrong!
  • GSPBASSESGSPBASSES Frets: 2354
    edited June 2023 tFB Trader
    Has anybody found a way of rout the binding channel on a droptop that works every time? Over the years I've spent hundreds of pounds buying all sorts of gadgets to do this job. None of them really work well so I gave up even trying to do it now. But if somebody knows a way of doing it I would be more than interested.
  • PabcranePabcrane Frets: 489
    You could maybe route from the back like Rickenbacker?
    If you were doing it on CNC that would work but you would have to hollow it out again from the back and fit a back to it rather than a droptop but that works as the Miris does not seem to have a belly cut on the one I looked at but Novo mix and match features a lot. As for bending, people put drop-tops on Strats with no problem so the much subtler arm contour on the Miris should be easy to bend across. I am thinking this one through as I like the Novo style of guitars, so as much as playing electric has been off my radar for the last 5 years and my sole focus has been getting lost in acoustic stuff making a Novo body might be a fun project to draw me back to electric.
    Doing a drop top is no problem at all. If you look back through some of my posts you’ll see I’ve done them on  Strat’s, Tele’s Jazzmasters and Jazz basses. On two of my posts, I’ve shown you how I bend and glue the drop top. It’s finding a way of doing the binding on a droptop is the problem.
  • MrTeeMrTee Frets: 511
    Misread title as 'Norovirus'. Carry on
  • If anyone fancies having a go at making one but doesn't want to bother with some of the intricacies like minding or the slope, I'm very happy to hear out!
  • JeremiahJeremiah Frets: 634
    It would be great if more of the guitar parts builders made interesting body shapes rather than just the usual Strat/Tele/Jazzmaster offerings, but still compatible with the standard Fender neck dimensions.
    I guess there would be copyright/trademark issues with copying some of the other brands' shapes.
    Warmoth do a few (e.g. Z-body, Musiclander) but they're pretty expensive to ship to the UK.
    Tough one. I guess most sales are for T and S-style with some sprinkle of offsets. However, yeah, I would love something a bit more adventurous and would be prepared to pay more for this.
    Copyright is a fair question and I'm 100% happy with an "inspired by" vs trying to do an accurate clone.
    Afaik @GSPBASSES does make some other shapes, maybe could do a Miris at some point ;-)
    Rosser Guitars make some interesting bodies, or used to, but they do not ship to the UK. I think they stopped making a lot of the interesting bodies as not many people buy them.
    I regret not getting a Harmony H44 body from them when they used to make them. He still makes a Fano LP style body.
    I suggest you have a look at my posting https://www.thefretboard.co.uk/discussion/242755/back-in-the-workshop#latest
