A brisket is basically 2 cuts together. The Flat and the Point. The Flat is very lean and the Point is more fatty.
The flat cooks quicker as there is very little fat to render down, but it can be over cooked more easily. The Point takes far longer but the fat content means it’s difficult to ruin it.
You can order one or the other from a good butcher and do just one.
If you do the lean Flat then I definitely recommend wrapping it during the cook to stop it drying out.
Trim it a bit, use a simple rub of salt and pepper and make sure the kettle is set to indirect heat. Oak is a really good wood for brisket for the smoke.
When the internal temp hits 200-203f it will be ready. When you wrap get the foil as tight as you can. You are trying to avoid it steaming in a package.
When done wrap the entire foil package in towels to keep it hot and let it rest for an hour. It will stay hot far longer than you think if you need to wait for meal time. It can rest for as long as you need.
For a proper sized flat I’d get it in the kettle at about 6M to eat in the afternoon. Get the kettle to 250f. With a flat only a lower temp is safer. You can always up the heat after it has been foil wrapped.
If it was a full brisket I’d be putting it on at 11pm the night before and staying up.
Minion method for the coals to keep it burning as long as possible between refills.
Try to do 2 things at once. So when you are ready to wrap have a handful of cold coals ready to be added at the same time.
Does anyone have any experience with the Weber Go-Anywhere? The other half wants one for the beach, looks good on first glance.
Top tip for the flat - only slice as you need otherwise it can dry out fast while waiting to be eaten. But do slice before freezing any left overs. Far easier to get as much as you need then, rather than trying to cut a frozen one!
Left overs make a fantastic chilli.
