New acoustic - easy on the fingers
colskicolski Frets: 20
I've been getting left hand finger joint pain, (suspect arthritis) and am looking for an electro-acoustic that is nice and easy on the fingers. Been playing a Martin 00018 for maybe 10 years, then a Seagull before that, and they have always required a bit of a "fight" to get nice tone, but I'm getting tired of the fight!
I assumed Taylor would be the logical choice, but I tried a couple and they had surprisingly high action. Any recomendations?
Will mainly be used for teaching, acoustic jazz and theatre work.
Circa £1000ish, Cheers!
  • WhistlerWhistler Frets: 322
    I find easy on the fingers comes down to guitars having a radiused fretboard (so that rules out classical guitars), nut width (what for you is an acceptable range between 41 and 52mm?) neck thickness (more than neck shape but that may influence you) and the body size (a dreadnaught and a parlour will have an effect on LH positioning. Is your LH wrist straight when playing?
    Is @razorbill 's Guild X-150 Savoy the sort of guitar you have in mind, perchance?
  • earwighoneyearwighoney Frets: 3498
    Instead of getting a new guitar have you thought about taking the guitar to a tech to have the action lowered.
    Your Martin 000-18 is short scale and it should have less tension that something longer scale.
    Also have you come across low tension strings? There are a number of them out there, like Newtone Heritage. I recently put on some Pyramid Silvers and they are a lot easier on the fingers than other phosphor bronze strings I have used.
  • CloudNineCloudNine Frets: 4284
    A lot of acoustics come brand new with higher actions to allow for people who prefer that, with expectation you can then shave the saddle a bit for everyone else, down from there. I think most guitars of the same scale length can be made to feel relatively similar in terms of playability, with the right saddle, nut and fretwork adjustments.
    If you are getting arthritis, I think your best bet would be to look at shorter scale models, or maybe find a guitar that sounds great tuned down a half step. Some really come to life in that tuning and it’s definitely a bit easier on the fingers.
  • rustneversleepsrustneversleeps Frets: 200
    edited July 2023
    I’ve tried Martin Flex core strings which seem to me a bit easier on my old the fingers.
  • colskicolski Frets: 20
    One of the nicest actions I had was a Peerless Martin Taylor Maestro, smooth ebony neck and jumbo frets - played like the proverbial butter.
    But I'm sorted for archtops, looking for an electro acoustic, (pref not jumbo/dreadnaught size).
    I've done a bit of work to it myself, nut, saddle, neck adjustment, I reckon it's as low as it'll go.
  • thermionicthermionic Frets: 9671
    Many new Taylors would benefit from a neck adjustment from an approved tech - it's just undoing three bolts and swapping out two shims. This is usually done under warranty if the action is out of factory spec.Worth asking at the shop that you tried them.
  • TheMadMickTheMadMick Frets: 245
    You could always try to tackle the problem the other way round. Arthritis responds to gentle exercise. Work out some finger flexing exercises for yourself and do them regularly and often. Say 3 times a day and then extend the length / number of reps with time. Rule of thumb (sic) 30 seconds or 30 reps to start unless you are having real problems but work from there.
    I've done this with my shoulders and hips. It's not a cure but it does help a lot.
  • AsterixTGAsterixTG Frets: 246
    The lowest 'easiest' actions I've played on acoustics seem to be ones by luthiers that specialise in more folk/finger picking type guitars - perhaps look for something designed for that. No good obvs, if you want to spank it hard or get a slide out. They tend to get a bit rattly then.
  • richman6100richman6100 Frets: 341
    This. I fought a bit with the action on my Furch grand auditorium for a couple of years. Initially, I figured that it was me rather than the guitar - my general cackhandedness combined with struggling to get used to the 45mm nut, which is wider than my other acoustics. Then I had Jonny Kinkead lower the action a bit and it's now so much more comfortable (i.e. easier) to play. My left hand used to tire quickly when playing it, now I can noodle on it for an hour or so without any issues. Worth a shot if you like the sound of the Martin you already own. Cheaper than buying something new too.
  • SoupmanSoupman Frets: 238
    Cheapest option would be to try Newtone Heritage strings at just over a tenner, but reading your comments I get the impression that maybe you're really after a new guitar.... :)
    I fought with my Lowden for years before getting it set up by a tech. The difference was unbelievable as others have said.
    Good luck with your search.
  • stickyfiddlestickyfiddle Frets: 27230
    edited July 2023
    Apologies if it seems obvious but have you tried a lower string gauge?
    There's far too much "wisdom" bandied around about beating ourselves up with thick strings in the name of tone
  • ICBMICBM Frets: 72642
    Try a Martin SC-13E. Very modern and unconventional for a Martin, but still has the 'Martin sound' to a fair degree. It can also be set up to play extremely easily and electric-like, more like a Taylor (the description of a high action on the ones you've tried is surprising, they don't normally) than a traditional Martin.
    If you're having a guitar set up, make sure the tech knows what you mean by *a properly low nut* - almost all are too high from the factory, and many even after being 'set up', and it makes a huge difference to the playability. As already said, lighter and/or lower-tension strings will also help. Newtone 11s are good.
  • elkayelkay Frets: 78
    When I started reading your post, the first thing that came to mind was 000-18, until I got to the bit where you said you had been 'fighting' yours for 10 years. I'm gobsmacked! In a lifetime of owning and playing a huge variety of top end acoustics, all of which have come and gone, the one remaining keeper for me has been my 000-18, which for me has easily been the easiest to play of all my acoustics. Some years ago i had a bout of carpal tunnel syndrome which stopped me playing for 6 months. I switched down to 10s and was delighted to discover that, not only was there no loss in volume, but the lighter strings actually brought more sparkle to the tone. I used to have a Taylor 812ce, which, on paper, might suit you, but I personally couldn't anything with it, whereas with the 000-18 I could do amazing things I couldn't manage on any of the others. Don't rush into looking for other guitars when you potentially already have one of the best. As others have said, try a professional setup or switching to lower gauge strings. If. as you say, the action is already as low as it will go, changing down on the 000-18 will actually lower the action even further.
  • Winny_PoohWinny_Pooh Frets: 7802
    It's quite simple. Take the Martin for a setup and progressively lower the string gauge.
  • Slash'N'burnSlash'N'burn Frets: 162
    I went down from Martin 12's on my acoustic to Martin 10's,  I was expecting it to be weak sounding and brittle but I barely noticed the difference, it sounds great.
    Probably best to get your hands checked out,  I wouldn't self diagnose arthritis, it could be various things even just overuse.  A GP should be able to arrange an xray.
    I do this for myself. I start by buying a new nut and saddle so that I can experiement filing those down. The original nut and saddle are safely stored should I need them or for when I sell the guitar.
  • BluesLoverBluesLover Frets: 673
    edited July 2023
    I am increasingly having arthritis type problems, and the best solution for me is a Taylor GS mini, with action lowered at saddle, and strung with 10's.
    Experienced acoustic players would probably dislike it, but it works for me!
    I'm intrigued by the claims for the Martin SC-13e, but it is too much money for me to justify right now.
  • sev112sev112 Frets: 2799
    I have found (I’m 57) that it’s really important to stretch my fingers and wrists before playing these days or I get wrist pain
  • thomasross20thomasross20 Frets: 4437
    Do yuo file the nut at the bottom or the nut slots?
