CPC
Farnell
Rapid
Dr Tweek
Tayda (mainly only pots these days, most of their other stuff is a bit suspect)
Boxes I use Camden Boss for 1590B and 125B sizes (they're actually a little different), I prefer them to Hammond when I can get them. I get those from CPC. All the others are Hammonds and I get them from either CPC or Rapid depending on which is cheapest for the ones I want.
Indeed, here's my little common parts list as I can never remember what we get from where when ordering:
Enclosures
CamdenBoss RTM5003/13-NAT (1590B) / white - RTM5003/13-WH - CPC
CamdenBoss RTM5004/14-NAT (125B) / white - RTM5004/14-WH - CPC
Hammond 1590A - Rapid
Hammond 1590BB - CPC
Hammond 1590BBLG - Rapid
Hammond 1590XX - Farnell
Hammond 1590XXLG - Rapid
Hammond 1590DD - CPC
Hammond 1590D - Rapid
Hammond 1550G - Rapid
Hammond 1590LB - CPC
Jacks
Enclosed Jack NYS234 - Rapid
Small Jack Stereo MJ-161M - CPC
Small Jack Mono MJ-159M - CPC
Open jack mono NYS229 - CPC
Open jack stereo NYS230 - CPC
Power Jack 8mm CN14799 - CPC
Power Jack switched MJ-10 - CPC
Switches
DPDT Stomp 780744 - Rapid
DPDT switch 750087 - Rapid
SPDT switch 750083 - Rapid
Musikding are the nearest thing to one stop shop I've found where you can get everything. You won't need them at the moment (unless you want to put LEDs on your switchers) but you can get resistors and other components as singles without paying a massive premium. Somewhere like RS is cheap but the minimum order quantities they have don't work for one off builds.
He's a good builder, is Mason.
http://www.thefretboard.co.uk/discussion/310/building-your-own-stompboxes
Would be nice if it's stickied. It is linked in the useful resources sticky in the Making and Modding section.
