I’ve been revisiting the HX Stomp; still impressive !
Interesting. I'd always dismissed the HXFX because of the lack of amp sims but the Sansamp Bass is the only one I'd actually need...
An input output jack on the side
Global buttons for noise gate and EQ
More pre-amp pedals (Echoplex, the Roland Chorus one etc)
Ability to rename the amps and pedals like it's Pro Evo
Level meter...please please please make it easier to get consistent levels across patches
Simplify the idiosyncratic model-specific controls, or have an option to do this
Expandable memory slot for the looper
Anyway they started sourcing feedback from users about six months ago. A new Helix is probably 3 or 4 years away.
What's your beef with the delay?
I think - if like you say development may already be underway for a replacement - speculation about that would certainly warrant its own thread!!
The current stuff is, as far as I'm concerned, way better that previous generations of modelling, would be interesting to see where it goes next!
It's an incredible piece of gear imo - I'm not sure what a replacement unit would have to do to supersede it.
As for the next patch upgrade, I'd definitely like to see more boosts. I know they aren't the most characterful pedals but there's clear differences between, say, an LPB1, a Super Hard On, and a Catalinbread Picoso, and I'd love to see more options on the Helix for sure.
Also - anything to further optimise the DSP!
If said amp had an FX loop you you stick the output of the Stomp into the FX loop return and run any preamp model you like (so it wouldn't emulate the power section nor speaker cab) from the Helix directly into your amplifier's power section.
You could then pretend the HX was a channel switching amp and toggle between two preamps, put any gain FX blocks before the preamp models and delays/modulation/reverbs after them (As if they were in the FX Loop)
Hopefully that makes sense!
