SPEAKER IMPEDENCE CALCULATOR
The one in the Zoom MS70 CDR. I've owned several individual gates. But none have been as good as the noise suppressor in the CDR, not only is it a great gate, it also gets rid of hums and buzzes.
You could take a pretty crude sample and cut the latency if you were using digitally controlled analog. With DSP I guess you can use lookahead and get really fancy
I have a DIY Zuul clone, a Stone Deaf noise gate and a Boss NS-2. To be honest they all do the same job once you get a side-chain set up. I don't notice any of them. The one knobbers are easier to use
