soundcloud.com/thecolourbox-1
Some also argue that transformer based preamps load the mic differently (input impedance) and you get more articulation from dynamics for instance.
Also, having a hardware compressor doing light work on the way in means you can be less likely to clip the converters with peaks and also have a decently high input level.
I use a great river single channel neve style pre into an LA-3A clone. But before you start spending cash get a great mic first.
In order of importance:
1&2
sound source>suitable mic & mic position
Then
3&4
>quality mic>hardware preamp/processor.
Of course if you cant mix for shit it'll will all be mush. But if you cover 1&2 well it's easier.
If you know what you like and experience tells you you're definitely going to eventually do X or Y to a track, just do it on the way in and move on. Then as the production comes together it already sounds pretty good. You get more context and mixing is easier because not only have you already done some of the work, but the processing has locked in a certain direction so you stay focussed.
if you don't do anything and put off making every decision, you get to mix time and you have not only billions of options, but billions of possible end results. It's a lot easier to lose your head going round in circles, going "Oh, do I want API or Neve breakup on the drums? What about a little Abbey Road EMI on the guitars? Oh, maybe Actually the API plugin breaks up better there... And then before you know it, you're auditioning plugins instead of making art.
Bandcamp
Spotify, Apple et al
Ebay mark7777_1
One of the reasons people tend to use compression and saturation on the way in is because on the whole digital sounds pretty uninspiring. I started out in the tape days on 8 and 16 track and just recording the drums to tape with nothing else added made them sound cool. Digital is great and clean and all that but basically sounds sterile in comparison.
I don't have any professional pre amps or compressors anymore so I tend to record vocals cleanly. With everything else though the sounds are printed. I don't use any amp simms, the amps are mic'ed and recorded. The only trick I do use is to record the part through the amps pre amp section with a speaker simm for monitoring, then when the parts good send it back out into the amps power amp section - into the mic and back into the DAW.
This process means you only have to have the amp cranked for the duration of the song.
