Edit - think "sloppy double tracking" lol
I also wonder if open back combos are more prone to it since they're inherently more phasey anyway, as part of their sound - since you've got the sound unimpeded to come out the back of the cab, bounce off the wall, and then back at you.
This is a part of the reason why I prefer no amps in my wedge, and to monitor from my own backline - less chance of a phasey, washy mess. The main reason is that it clears the monitor mix for vocals.
Bandcamp
Spotify, Apple et al
I need guitar in the mons as I'm over the other side of the stage for part of the set. If we'd had more time for a proper sound check (often impossible at festivals!) I might have had no guitar in the mon by my amp, but plenty in the mon at the other side. Something to think about in future for sure...
I figured out quickly that it was a stage-only problem and wouldn't affect the FOH sound, but it's distracting when you don't really know what the audience is actually hearing!
Bandcamp
Out of phase mic leads. A mic cable with pins 2 and 3 swapped over one end will still work perfectly but will put the signal 180 degrees out of phase. People buy a single mic lead, it works perfectly and they never consider this issue but if you then use that cable as a feed for an active monitor or PA speaker ... or worse of all on of a pair of overhead mics you will run into problems.
My rule with festivals is always crank your backline for yourself and get a rough mix of everything else in the wedge in front. Then you physically mix the balance by standing nearer or further to the backline or wedge.
I played the big top at Victorious festival a weeks ago and I cranked the supplied AC30 right up, sounded glorious !
