https://www.youtube.com/watch?v=4Bma2TE-x6M
Even just editing all of that footage would take weeks - he must really have a great way of cataloging all of the audio and video he does so that he can match it all together when he's editing.
Do YouTube give awards?
Im already looking forward to his next and wondering what the subject will be ?
Jim Lill does a microphone overview - Studio & Recording Discussions on theFretBoard
Ebay mark7777_1
If you're interested in comparing mics, Audio Test Kitchen has done the same thing much more rigorously.
I think the video is great and mirrors a lot of my experiences when using mics that cost huge money £10-20k and comparing them to cheaper or even budget alternatives in the same recording sessions.
All his mics sound terrible on the speaker, so I'm assuming the speaker itself is the issue. There are plenty of good dual concentric monitors on the market right now, why not just use one of those? Since his home-made speaker hasn't been calibrated or measured in any way, we have no way of knowing what its useful frequency range, what kind of resonances it has, or how much of the sound is radiated by the cabinet rather than the speaker itself. The chances are his mic measurements are worthless below 200Hz or above 5kHz.
His home-made jig allows him to line up the front of each mic in the same spot every time, but that's not actually what you want. What you need is the ability to line up the capsule in the same spot every time, and not every mic has the capsule the same distance from the front. Take a look at how Audio Test Kitchen do this with lasers.
Unless he gets into it later on in the part of the video I didn't watch, he doesn't seem to discuss polar pattern or off-axis response, which are both huge factors in the sound of a mic. Nor does he discuss smoothing and how that affects his graphs.
Anyway...
How can it be true both that the differences between mics are not as large as everyone would have us believe, and also that vintage mics vary a lot?
I think a lot of this "all mics actually sound the same" stuff arises because people are using their mics for the same applications all the time, and those don't tend to reveal the differences. For example, if you only ever use mics to record close-up vocals in an acoustically dead space, the main difference you'll notice is that the tone of the recorded voice changes a bit. And you might well find that an SM7 suits the singer better than a £10k vintage valve mic. You might also find that you can make them all sound quite similar in that particular application using EQ.
But that's like saying all cars are the same because you only ever drive them down the High Street at rush hour. Try using those same mics as the main pair for an orchestra, or as overheads for a jazz drummer, or to record a church organ, or for spot miking an operatic soloist. No amount of EQ is going to make your SM7 sound like a C12 now.
The world of mics is a bit like the world of guitars in that it has become quite conservative. A few old models are held up as the 'gold standard' and thus develop ridiculous second-hand prices, and a lot of new mics are basically copies of those old ones. Meanwhile genuinely innovative, high-quality new mics sometimes struggle to gain a market share.
It has gone to crazy extremes, but I think there's a bit more justification for this in the case of old mics than in the case of old guitars, and that's because it's much harder to copy everything that contributes to the sound of the original. No-one is going to make the VF14 valve again, and nothing sounds like it in a U47. Many people have tried to copy the CK12 capsule, and most of them sound nothing like the originals. No-one can recreate the aluminium capsule used in the M50.
So, if you want to buy a C12 it'll probably cost you upwards of £15k. But if you want a clone that actually performs like a C12 that won't be cheap either. Go to Warm Audio or Peluso or Golden Age and you can get something with the number 12 in the model name that looks quite similar, but it won't have much in common with the original. A Squier Strat is much closer to a holy grail Fender than a Chinese U47 copy is to a real U47.
There are also quite a few classic mics that don't really have a modern equivalent, which also drives prices up. No-one makes anything similar to the AKG D12, D19 or D224 today, for example.
Apologies, I seem to have written an essay...
We now live in a world where there are very few Abbey Roads, and £30k for a mic is a disproportionate expense in the context of a home studio. But you can't blame the mic for that.
I've heard a few high end mic comparisons on gearslutz with vocalists that will make you think. I've also done a fair bit at home.
A 6 inch speaker is of little benefit here.
I guess my biggest problem with this video is summed up in the title: "Where does the tone come from?" The concept of 'tone' is dubious enough when it comes to guitars or amps. It makes no sense in the context of microphones.
Consider omni pencil mics. These come in two types: diffuse-field optimised and free-field optimised. If you use a free-field mic to record something at a distance, it'll sound dull. If you point a diffuse-field mic at something close-up, it'll sound uncomfortably bright. That's not a fault in the mics, or anything to do with their 'tone'. It just reflects their design and intended use.
As @Stuckfast has already pointed out, he is testing just one specific mic use-case. What about omni or figure-8 patterns? They have completely different applications and may sound terrible in a test like this.
As always in subjective audio matters, the takeaway is: use your ears.
Incidentally, @Stuckfast , I'm currently experimenting with the Decca .Tree.recording process and, as u can't afford.M50 mics, I'm using Behringer omni condensers with plastic balls fitted over the capsule!
R.
Eqd Speaker Cranker clone
Obviously it's not perfect and cardio/omni/fig8 would give different results in different tests, but he's making YouTube videos, not going for a Nobel prize.
Ebay mark7777_1
I had seen loads of little studios spend 20K on a space for the studio and 40K or so in mics and pre amps. Me and my studio partner went the other way, over 100K on the space but only 20K ish on desk, mics and a bit of outboard. We never had any nice pre amps or any expensive mics. Lot's of good work horses like 57's and 81's etc but no high end vocal condensors or nice ribbon mics. And we suffered for that booking wise and so did the quality of the recordings. Everything we did was ok but always a little too clean and soulless IMO. Conversely some of the people I work with now have small spaces but some great mics and lunchbox pre amps and they are getting better tracking of vocals and guitars than I ever did.
It's a fun video but missing the point on so many aspects.
