FS/FT: Marshall SC20C / ZT Lunchbox / Orange Rocker 30
Jeddy3Jeddy3 Frets: 81
edited June 2 in Amps £
Marshall SC20C JCM800.
Only recently picked this up but now need something Fender flavoured for the band I’m in. Sounds amazing and is in immaculate condition
Price: £595 (collection preferred but could post at cost).
ZT Lunchbox LBG2 (Original).
Had this one a few years now and used it quite a bit. Sounds lovely plugged into a good 1x12 cab. Not really used much the past year or so though so moving it on.
There’s a small dent on the edge and some wear on the bottom corner. The control knobs also have a slight discolouration on the sides. The amp is working fine though.
Would trade towards a Boss DD8 delay or Way Huge Russian Pickle.
£220 Shipped
Orange Rocker 30 Combo
UK made Orange Rocker 30 1x12 combo from around 2007/2008.
Only recently picked this up as an ex (NOS) store display but I just can’t get along with the Orange sound. I’ve tried 3 Orange amps now and I just prefer the bite of a Marshall.
Features a natural/clean channel (with no EQ) which is designed to drive the power section only when cranked. Then there’s the gain channel with the usual treble, middle and bass EQ and a gain and master volume. 2 x EL34’s and 3 x 12AX7’s.
 It’s in near enough mint condition apart from the tiniest of scrapes on the lower right hand front corner. The rear chassis panel screws have been changed to heavier duty chrome/steel as the original black ones chewed up really easily and a couple were actually a little warped. The current ones are much better quality and don’t look out of place. Speaker is now the stock Celestion V30 (photos show the Jensen Stealth I briefly tried).
Note: The Pre amp tubes may need changing soon as they rattle a bit  at high volumes.
Interested in trades for the following….
Fender ‘68 custom Pro Reverb
Fender ‘65 Princeton Reverb
Fender Hot Rod Deluxe
Roland JC40
Other options considered.
Ideally would prefer collection/meet up due to the weight but I can pack it up if the buyer wants to sort the courier.
Asking £500 (Was £595)
Cornell Romany 10
Lovely little amp this and very well built but I find myself using my little Marshall JCM more hence the sale. Would also like to try something more blackface and less tweedy.
Made in November 2022 and Hand wired in the UK. It’s based on a 50’s tweed champ circuit with a single 6L6 power tube and ECC83 in the pre amp. It’s got built in power scaling with 4 settings (10 - 0.05 watts) along with an EQ tone stack switch which allows you to flip the treble, middle and bass controls in or out of the circuit. This is very useful if you find the thick midrange of the tweed circuit a little too much.  It’s had the speaker changed to a WGS Veteran but it’s otherwise stock and in pristine condition.
Now £625 (Was £750) SOLD
Collection or meet up in Southampton or Portsmouth preferred but can pack up and ship if buyer is happy to arrange a courier. Located on the Isle of Wight.
Cheers
Dan
«13
  • Bump
  • Bump
  • Bump
  • Bump
  • Bump
  • Jeddy3Jeddy3 Frets: 81
    Bump
  • Always wanted one of these in the past
    It is a lovely amp. Impressive build quality for not a lot of money. Why don’t you treat yourself?
    Bump
    Bump
    Bump
  • FastEddieFastEddie Frets: 582
    I have one of these and it is simply the best tone I've heard. Anyone who wants quality and a gorgeous tone should jump on this. Mine takes fuzz, modulation, and drive with ease. Utterly superb. GLWTS.
    If I had talent, I'd be talented.
    Injured Veteran and head injury survivor. Bouts of grumpy behavior and brutal humor are to be expected.
    Red meat and functional mushrooms.
    Persistent and inconsistent guitar player.
    A lefty, hence a fog of permanent frustration
    Not enough guitars, pedals, and cricket bats.
    USA Deluxe Strat - Martyn Booth Special - Epi LP Custom
    FX Plex - Cornell Romany
    Thanks for the recommendation!
    Bump
  • CMW335CMW335 Frets: 2061
    Hi
    Would you be interested in part trading the Cornell against a 1978 Tele? It’s all original but the blonde finish has been stripped
     https://imgur.com/gallery/YPfIvmO
    CMW335 said:
    Hi
    PM’d
    Bump
    Bump
    Bump
    Bump
