https://edmorgan.info
The G7th Heritage is spendy, but by far the best ive used.
my fav of the lot. Worth the money I’d say if you got an expensive acoustic I’d say get one. Otherwise a kyser does the job. I’ve got the same kyser I bought 20 years ago and still
works the same…
I only prefer the Kyser because having the hand grips above the fingerboard somehow feels more natural than behind the neck, to me - otherwise, it’s a good second choice.
I have just been given one of these (G7 Performance 3) for my birthday - 68 - Thankyou.
Firstly it's a nice little object to handle. Not clunky like some capos.
Does it work? Yes. very well. You can use the strength of both hands to tighten it once you've positioned it. It holds tuning and does not cause the strings to buzz.
Does it work well on a variety of different neck widths and shapes. Yes.
Does it knock against Lt hand ? I've had lots of different capos. Screwy ones, rubber bandy ones, springy ones: and I think this is the one which knocks up against my Lt hand least. Jim Dunlop wrap-around elastic capos are good in that respect but fiddly to use. I think part of why the G7 is out of the way of the Lt hand is because you can position it mid fret and it won't buzz. Other capos you have to position nearer to the fret for them not to buzz.
Is it easy to use? Yes. I don't have any particular reason not to use both hands when fixing it in place and it's easy.
Is it good value? Yes I think it probably is.
Any criticisms? For this price a case or bag would be nice (although I shall use the bag from my present capo).
So - is it better or just different. Yeh; better I think.
btw this was my best Birthday Card
Do i literally just squeeze it hard to get the correct down-tension on the top and bottom e's?
