As long as you stick to amps that suit your cab it's like having a traditional set up and every effect you could think of.
The only reason I stopped was I got fed up constantly taking it back and forth out of the studio.
So on a modeller I tend to use boosts more rather than just using my own dynamics to make fills and solo's pop out in the mix.
This is brought about mainly by "needing" to cut down on the amount & weight of our gear, plus(i've not read this mentioned in the thread) by the time the drummer gets excited with his accoustic kit & i get my Modded ORI50C in it's sweet spot, we're getting loud (& of course the Bass player is to loud to start with), we're getting away with the volume some of the time, but not all of the time.
Oh we always except for one regular gig use our own PA, which we also intend to go lighter with,if we start getting somewhere with the "experiment.
I'll report back on our "progress" or lack of it
I haven't however messed with the some of the various 'compression' aspects of the Kemper to try and mimic the behaviour as for me a bit more compression is fine. I'm probably a worse player now as a consequence however and I do get caught out and have to play with a bit more care with a trad setup.
I don't use valve amps live any more though as the benefits outweigh the disadvantages..
I'd be interested to hear the experiences of people who have closely compared modellers with attenuated valve amps, that would seem like a more realistic comparison when it comes to this "gets louder when you dig in" point. Similarly, do any regular non-stadium playing punters use modellers at the loudness levels you'd need to get a plexi or similar to start breaking up to know how they behave in comparison?
I'll have a go and feedback (if the volume is too high
Si
It's strange really as the pedals on my board can only swing 4V at best and yet there's no lack of dynamics and headroom. The Pod Go on the other head just doesn't respond in the same way. Maybe it's the convertors, maybe it's just something with the DPS code.
I'm not anti digital, I was probably one of the first on the forum to go over to a digital desk back in 2008 when they were big money and I mix on digital desks all the time on a freelance basis.
I've had 2 HX Stomps and sold them both as I was tweaking too much. My plan was to try the Boss IR-2 as at least you're limiting what you can mess with, and no menus. The Two Notes system is crazy to me, just so many options to mess up and over-engineer your sound. I tend to just use 1 of 3 York Audio mix IRs (depending on the amp model) as I know they sound good and have been mixed by someone who knows what they're doing
I’ve been using a CRS lately, too, albeit mine is a 50w head and 1x12 cabinet and I’ve found the opposite in that it’s been a visceral thing that seems to dominate a band mix in a way my FM9 could never achieve. Pretty sure I’d dial them similarly, given I’m the same person twisting the knobs. Was gonna sell it, but I’m not sure. I’m finding it to be particularly good at being a rock amp and it’s surprising me. Need a shove in the front end to be at its best, though.
Having been all valve/analogue until the first of the Helixes came out, I then dipped my toe into the modelling world.
I think I've been through the Real Amp>Digital>Real Amp>Digital merry-go-round several times and always have given each approach a lot of gigs to make my mind up.
As of a few months ago I sold my most recent amp and now my current set-up is the HX Stomp XL direct to FOH, with a Fender FR10 for my monitoring. Although, as rightly pointed out in this thread, that's not much different size/weight-wise to having a smallish valve amp and a pedalboard, for me I reverted back to this set-up purely becasue I just prefer the sound.
I tried a big variation of different pedals to pair with my last amp and just never hit on anything that pleased my ears that much. I actually found I was doing more constant tweaking and chopping/changing in this scenario, whereas many seem to find they have that experience more with digital gear and its myriad available options.
A bit of a win for me has been to basically ignore most of the deeply-technical chatter and ultra-complex signal chains you read that people are using. My signal path is about as simple as it gets and I barely have to go menu-surfing at all. If it were any different I would have given up on the digital journey ages ago.
It may be sacrilege to say it but I think I've adjusted to preferring the sound of the digital models of a mic'd-up amp through an FRFR over the more 'raw' sound of a cooking amp on stage. It seems a little more refined, more controlled and seems to blend better on stage to my ears. But then I did think that same thing 2 merry-go-rounds ago, so what do I know?!
I think the current state of modelling gear is so good now that for me it's not just about achieving some downsizing project.
For me, comparing a modeller to a valve amp is pretty much the same exercise as comparing one valve amp to another. You always end up with a preference based on whatever your ears tell you.
By the way......discount on my modelling gear to anyone in this thread when I decide to sell it and buy a Marshall stack.
