But then again something like the JCM needs vastly different settings depending on which input is being used so it wouldn't be that much use to have anyway.
There should be a ban on shared EQ, gain and output!!!
It's just a legacy of old amp designs. The choice can be useful - if you have hot pickups and are running out of headroom too early the low input can be good. If there's a bright cap on the channel vol & the amp is too bright at the volume you need, you can reduce its effect by using the low input and turning up to get the same overall volume. If there are multiple channels with two inputs, you can use the spare input to jumper the channels and blend to taste.
Bandcamp
Spotify, Apple et al
My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
Guitars with single coils -> low input.
Guitars with both -> panic attack. We did not plan for that. Please burn your guitar. Or buy two amps and a switch. Yeah, two amps and a switch will do, thank you. Actually, it works like that by design. It's a signature feature of the amp, and we'll sue your arse if you try to copy it.
The high input gets you that classic JCM800 crunch but in doing so limits your effective pedal choices and for me it encourages you to work the guitar volume control far more to achieve semi clean type sounds.
Bandcamp
The high and low inputs thing just feels like a legacy from yesteryear that is done because 'we've always done it that way'.
https://edmorgan.info
Basically a dirtier, more controllable Super Lead.
Worth bearing in mind that the 2203 JMP Master/JCM800 circuit was designed barely a decade after Marshall started out making amps. It really is a 'legacy' product, electronically far closer to the 1959 Plexi than anything remotely modern.
Not sure I agree.
Most amps with two fully independent channels sound so different I struggle to use both and end up just sticking to one.
My '79 JMP 50 has them. For me it was High=guitar low=out a bass through it. Low sounded good for bass or certainly good enough for me then. I did that for years when I was doing both bass and guitar band work.
If you want an amp switcher then there are plenty of options that offer that.
The other is like the Marshall 2203 or Mesa/Boogie Mk I, where the 'High' (or 2 on the Boogie) jack goes through an extra valve stage to create much more gain and overdrive. Depending on how the routing is arranged, you *may* be able to switch between them externally - at the expense of a huge volume jump when you use the High, unless the amp is already fairly cranked so it just overdrives further.... so still not that useful for most purposes. With the 2203 I've always preferred to use the High input with the guitar straight in - it just sounds better, even if you want a semi-clean sound with the gain down a bit (although I usually just set it at 10 and use the guitar volume) - but the Low input if I'm using an external pedal or multi-FX for overdrive.
I have another with one input with switchable clean/drive channels. Only ever use the clean channel and again do everything with pedals.
I have a third with high and lo inputs AND switchable between a clean and drive. Only use lo input, clean channel and yes you guessed it, pedals.
If you run two amps in the rig it seems to be the way to go.
